Thread: Cracked Bubbler
    Feb 2018
    Miami, FL
    2
    Cracked Bubbler
    I have a pool leak which appears to be coming from a cracked beach bubbler. I've been given several expensive repair options and was trying to find a cheaper solution. Can the crack be sealed? I don't care about the light. But, I would like to keep the bubbler function.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,043
    Re: Cracked Bubbler
    I have not heard of anyone trying to fix one so am not really any help I am sorry to say.
    Do you know HOW it works? What are those little, darker "holes"? Husband said you could TRY JBWeld if you really wanted to try. It could not hurt except if it does not work you will not be able to get it off so................proceed with that in mind.
    Kim
    Feb 2018
    Miami, FL
    2
    Re: Cracked Bubbler
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks for the reply! The 4 holes are where the screws go in for the LED light, which goes on top of the bubbler. I think we will try JB Weld or some other Epoxy sealant. There's really nothing to lose by trying it. The next option is to seal it entirely.
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,375
    Re: Cracked Bubbler
    I think you should be able to seal that easily with JB Weld or some other sealant. Looks like it may have cracked due to the screw however but that doesn't seem possible with that metal screw sleeve. If that screw isn't integral to the part I would leave it off.
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
