Results 1 to 9 of 9
Thread: Zeolite
    Feb 2018
    Fort Wayne, IN
    1
    Zeolite
    I need to change filter sand this year...before opening in mid-April. Has anyone tried Zeolite sand? If so did it work any better then regular pool sand? The first 2 years my pool was easier to take care of....but last year especially was lots of chlorine....kept getting chlorine demand. Any thoughts?
    Joe S.
    In ground 14,000 gallons...Fiberglass pool...Pentair equipment
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Zeolite
    Welcome to the forum!
    Not sure what you mean by chlorine demand but algae and a large consumption of chlorine over normal is not a filtering problem but a chemistry problem. How do you test your water? How do you chlorinate?
    I would suggest searching for Zeolite in the box in the upper right of this page.
    From what I have seen, sand is best. It also rarely needs to be replaced. It has been here for millions of years and it would be hard pressed for you to wear it out in a few years. Now, if you have used pool store potions (clarifiers, floc's, etc) they may ruin it, but you should never use those anyway.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Nov 2017
    Corpus Christi Texas
    4
    Re: Zeolite
    Zeolite anyone have any experience with it yet?
    May 2013
    North East Ohio
    987
    Re: Zeolite
    Quote Originally Posted by InfoKid View Post
    Yep don't do it
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Nov 2017
    4
    Re: Zeolite
    Quote Originally Posted by toofast View Post
    Yep don't do it
    I am looking for more information, to make a better informed decision about Zeolite.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,322
    Re: Zeolite
    While you wait for replies, try the search box upper right of each page. Then you'll get information from people who no longer visit the site much.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    10,021
    Re: Zeolite
    The general consensus for members who use it is that it works. It's does not appear to be wiz bang better, it works. But, it's a lot more expensive than regular old filter sand.
    But, sand works. We have found that folks blame lots of pool issues on "their sand" when in fact the sand has little to do with the problems they are having. Sand doesn't wear out. The only folks who say it does are the same folks trying to sell new sand or selling Zeolite. As Marty said above, seldom are problems a filtering issue, but more times than not they are a chemistry problem.
    Support the site
    Apr 2018
    Grand Rapids, MI
    50
    Re: Zeolite
    Quote Originally Posted by tim5055 View Post
    This has been my experience with it so far. I'm not really convinced it's working as well as they advertise it should (which may be a byproduct of the nastiness I started with), but it is working nonetheless.
    Additionally, backflushing Zeo needs to be done carefully. Its lower density makes it more prone to get stirred up and ejected with waste water, at least with my system.
    32' x 16' x 4' (approx. 12,000gal) Doughboy Above-ground Oval, 1.0hp Pentair Optiflo pump, Hayward S180T 150lb filter w/ 60lbs Zeo Ruby sand
    Nov 2017
    4
    Re: Zeolite
    Quote Originally Posted by kmerkel View Post
    That is very interesting I did notice how small, almost dust like it looked. Thank you for your reply.
    One benefit is not having to haul 700lbs of sand, for the two filters onsite. I like sand due to it being what works in most pools already. But I need to be open minded to trying new things and share the experience with others. Thank you for the input.
