Results 1 to 7 of 7
Thread: Buried Above Ground Issues- HELP!
    violet-mermaid's Avatar
    Mar 2015
    Baton Rouge, LA
    73
    Hey guys-
    So we had an issue with one of the sides of our buried above ground pool caving in. The installer did not mix any cement/sand for the top half of the pool and we think this is the cause. My husband dug out a HUGE pile of sand/dirt where the side caved in- but now it's full of water from the rain! We plan to pump it out and then add the concrete/sand mixture and hope it corrects itself. Any thoughts or tips? I really don't want to have to drain the pool if possible!!!
    Another issue is that the vaccuum we bought has never worked great for us. It always stops in the pool. We were told that the pump was not strong enough so we bought a larger pump last year and it still stops. This is the vaccuum we have:
    https://www.amazon.com/Hayward-900-S...+whale+vaccuum
    Is there another vaccuum you recommend? Our pool is a 12 x 24 oval and the pump we have is a
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Thanks for your time!
    12 x 24 Buried AGP 6,800 Gallons | Intex 16" Sand Filter | Intex Krystal Clear SWG
    Hayward Thru-Wall Skimmer | TF-100 Test Kit |Hayward 900 Wanda the Whale
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Buried Above Ground Issues- HELP!
    Please take and share pics of what you are dealing with as far as the sides and sand. I am not really understanding what needs to be done from the words.
    My Wanda has always been just "better than nothing" but I have had enough and am looking to buy a robot. She stops, she does not pick up the leaves, she does not get the whole pool, etc.............she is heading to the dump!
    Kim
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,188
    Depending on conditions for my 16x32 AGP, I either use my Pool Rover Jr.............or 90% of the time..........my Pool Blaster Max. All that dirt and stuff never makes it to the filter.
    Apr 2014
    Tampa area, Florida
    170
    I really like my Polaris 65. I leave it in 24/7. It occasionally gets tangled on itself or gets stuck behind the ladder, but works really well most of the time.
    Embassy 18 x 52 Elite Sea AG, Doughboy Skimmer, Black Diamond Filter 1.5hp, Intex Saltwater System Model #ECO6110, Polaris 65 "Dory", TF100, 2001 Hotsprings Landmark Hot Tub
    Pool Thread: New pool build Backyard: Our backyard paradise is almost complete!!; Added TIC gs4 8 dvc speaker....love my sound system!
    Casey's Avatar
    SW PA
    10,515
    If your pool wall is out of track, you will need to drain it and possibly do a reinstall to get it back in track. Do not drain the pool until the ground water subsides and dries up or you will risk losing the pool shell due to ground water. You will need to dig out at least a foot arount the whole pool to do a reinstall so you have room to work.
    As Kim said, pictures would help us tremendously so we can see the issue and give you the best advice for your situation at hand. Usually, pools that cave in are out of track. It could be ground water pushing it out, depending on how deep the pool is buried. You never mentioned how far in the ground it is nor how much water is in the pool.
    Mar 2015
    Baton Rouge, LA
    73
    How do we drain this pool?
    RoxxW's Avatar
    Dec 2016
    Poquoson, VA
    120
    Pull the return line from the wall and let it drain to that level. This use a garden hose to siphon the rest. You can rent a submersible water pump at a rental store for faster results.
    Yardmore 18'x33'x54" Saltwater LX Oval Pool Semi Inground 18K Gal, Hayward XStream 150 Cartridge Filter System 1.5-HP Power-Flo Pump, Hayward Aqua Trol RJ Salt Chlorine Generator System, Hayward Thru-Wall Skimmer & Return Fitting, SmartPool PT7i Inground Climbing Robotic Pool Cleaner, TF-100 Test Kit XL Option, https://drive.google.com/drive/folde...kk?usp=sharing
