Results 1 to 8 of 8
Thread: Shotcrete vs. Vinyl ...Owner Build
    Jun 2017
    Nashville, TN
    155
    I am trying to decide between a 16x32 rectangle with 6" radius corners and full width vinyl over steel steps, versus roughly the same dimensions shotcrete, but not exactly identical, probably add a couple things that can be added with a concrete pool that are not really possible with vinyl.
    I tend to DIY. No matter which option I go, I intend to:
    Dig/excavate
    Plumbing
    Electrical
    Coping
    Decking
    Landscaping
    These items seem to be basically the same no matter which route I go...both labor and cost.
    Things I intend to hire out on each type
    Shotcrete: Steel, shotcrete, plaster, and startup
    Vinyl: pool floor, will have to pay for concrete truck/pump for wall supports and the hopper, will have to order gravel for backfill. I will install walls, and will also do the backfill
    The vinyl kit I am looking at on at PoolWarehouse is somewhere in the neighborhood of $10k-$12k, depending on exactly which options I go with. Plus add the concrete truck and pump, the gravel...probably hitting $15k-ish. I have not gotten any quotes for shotcrete. Call me crazy, but i feel like the shotcrete will be less work on my end and give me exactly what I want.
    Am I missing something major?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,029
    Re: Shotcrete vs. Vinyl ...Owner Build
    I like the shotcrete due to the freedom to make it shaped just like you want and no worries about anything cutting or tearing the liner. I have dogs, big dogs, so.....that is an issue for me.
    I really think it would be worth while to check out the prices just to see what it would cost you.
    Kim
    Nov 2011
    Moberly,MO
    1,036
    You are right that shotcrete will be less work for you as most shotcrete crews prefer to do the forming and steel. But anymore vinyl can do pretty much anything shotcrete can do.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jun 2017
    Nashville, TN
    155
    Jun 2017
    Nashville, TN
    155
    This is what we are leaning towards. 16'x34', full width steps, and ideally have the second step be a 3' wide shelf. I also found a pic of a full-width deep end bench that I love, but not sure if I want to go that route or not...really just adds $$ and complexity. My hand drawn pic shows 36', but I think that is just too long for our yard, we are slightly space constrained.
    Jul 2012
    Tallahassee, FL
    35,029
    OH I like that BUT if you want to swim laps you will have to flip/turn at the benches. Will you notice them if you are swimming hard? Now if you swim like I do-VERY casual then you will be fine. There is a lot to like about the above set up!
    Kim
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,185
    Shotcrete. Your choice of depth and design.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
    Aug 2017
    Succasunna, NJ
    393
    Im about to start mine I got my kit there too, 8k and change but 14x30 fiberglass steps. liner over stairs is tougher for DIY, but can be done, the benches etc add to the difficulty. steel stairs need reinforcement, helped a buddy do his last year we threw a bunch of metal studs into them in addition to what came w steps, they were bouncy but rly nice. Its never gonna be same #s between kit and concrete, you are gonna sub the concrete and rebar out and the plumbing is tricky w concrete, plus figure in water tiles, and stone or tile on raised beams, and plaster job, you are gonna be a third higher at least, this is based on my area. I was gonna do fiberglass for mine but I couldnt find a shell for less than 17k delivered in my size and thats my all in # w fence too so Im going steel route. I ordered no border on my liner, doing paver deck to match my new walkways I did, my buddy did same and you cant tell its a liner unless you know it is. You can still do raised beam and similar with steel studs and cement board then cover with tile/stone whatever like outdoor kitchen guys build them on a steel wall pool
    14x30 IG 13,000gal "full DIY in progress" hayward automation, aquaplus swg T15, hayward swimclear 525 sqft. cartridge filter, hayward ecostar vsp3400, raypak 266btu NG cupro-nickel heater, dolphin S200 robot
