I just replaced the controller board on my Aqualink (old controller board was J and had issues with my spa-side switch, replacement is MM and runs the switch correctly). After the swap, the Aqualink does not seem to recognize the Aquarite and the Aquarite "remotely controlled" LED is not lit. I connected the RS485 and even tried a new wire - no difference. I also tried setting the Aquarite to AL-5 and power cycling, still does not recognize it.
Thanks
Thanks
