Thread: problem with pump
    Feb 2018
    Burleson, TX
    1
    problem with pump
    We purchased a Jacuzzie pool pump from Leslie pools in Oct 2017. Since then my bill had increased by $250 a month. Found out my husband is setting it on high because the inflow is almost nil unless on high. I have contacted Leslies to come out and check the pump. They did install it. I was not aware it was so new and may not be the best pump.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: problem with pump
    Welcome to the forum!
    Once Leslie's comes out come back here and let us know the issues. If you have any questions, post them up here.
    We could use more information if you wish us to help you. A signature really helps - see Pool School - Read This BEFORE You Post
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,915
    rb,
    Welcome to TFP... A great place to find the answers all your "Why can't my husband do anything right?" questions...
    If you can, tell us if your new pump is a two speed or VS pump.. If a VS pump, what speed is it set to run on "high"?
    If you can, please post the P/N of your new pump...
    What HP was the original pump? Was it a single speed pump?
    Thanks for posting,
