Thread: Robot returns to the same step
    Apr 2015
    Allen
    61
    Question...my pool robot keeps winding up in on the same step of the pool every day. Is it broke or?
    Dig 4/12/17, Gunite 4/19/17, Deck Installed 5/2/17, Plaster 6/12/17
    13,000 gallon, 24 x 19 rectangular pool/spa, platinum quartz plaster, travertine deck with raised beam in sloped yard. Polaris 3900 Complete, Jandy vsp 2.7hp, Jandy JX1400 Natural Heater, Jandy PDA PS6 (Pool/Spa), TF-100 Test Kit.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,883
    Re: Robot returns to the same step
    nate,
    Do you have the Polaris 3900 or a robot?? The 3900 is a pressure side cleaner and not what is considered a Robot..
    I only ask so that you will get better answers...
    In either case, my question would be, does it just stay on the stairs or does it go out and clean the pool and then "magically" come back to the same place?
    Apr 2015
    Allen
    61
    You are correct. It is a 3900(not a robot). Essentially I'll put it on the other side of the pool and gets stuck on the stairs. It never happened during the summer, I just noticed recently.
    Reclayborn's Avatar
    May 2016
    Flower mound, tx
    14
    My 3900 was getting stuck on our deep-end step as well, but the backup valve always kicks in and moves it after a few minutes. One thing that did help was replacing the tires on it. Mine had worn way down, the new ones added about 1/4" and that made a difference as far as it catching on floor-to-wall transitions. Make sure your backup valve is working though, it should cycle on every so often to move it in case it had been stuck.
    - 18k gallons, in ground plaster, dual floor and dual skimmers, city water, Polaris Sport 3900 w/ booster pump, Purex Triton 350 Minimax plus heater,
    Pentair Triton II TR100 sand filter w/ Century Centurion B855 2HP pump and Pentair Sm20-3 mulitport, Compool Cp3400 indoor control, Lx3400 outdoor
