Results 1 to 10 of 10
Thread: Does my valve need replacing?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Hey, so when running my water feature, the Goldline valve leaks when I activate it. It does not leak when I have the valve deactivated. See attached video. Does this mean the entire valve is done for and I need to replace or should I be taking it apart to fix something inside it?
    pool valve broken - YouTube
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,849
    Re: Does my valve need replacing?
    Mo,
    They sell rebuild kits for these valves... Just looks like a seal is gone...
    Just in case you did not know, the electric actuator comes off and the valve is underneath. A few screws and it comes apart.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Ok so everything in the actuator section is good then Iím assuming. Itís nice and dry and works appropriately with my remote to open and close.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    I took the valve apart. What part would I need to be finding? The middle piece that labeled DIV-20? The top cover piece or the o-ring that goes around the threads of the cover piece?
    Jul 2014
    Bedford, TX
    9,849
    Mo,
    If I went to all the trouble to open the valve, I would install the "kit" that comes with all the replaceable items...
    I would also look inside and make sure nothing is cracked in the maim body of the valve.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    I think I found my culprit
    Jul 2014
    Bedford, TX
    9,849
    Mo,
    Just put a whole tube of pool lube on it and stick it back together...
    Glad you found it...
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Well this just got a whole lot worse. Crack the whole piece when screwing things back on. Iím thinking of just getting in someone to fix everything thing now since it involves a lot more work
    Jul 2014
    Bedford, TX
    9,849
    Mo,
    As a general rule the holes strips out before anything else happens..
    I suspect maybe the crack was already there...
    Unless you used one of the screws holding the actuator on.. I believe they are longer...
    Sorry...
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Quote Originally Posted by Jimrahbe View Post
    Mo,
    That's what it cracked. I used one of the actuator screws thinking I would screw them in a bit to test the valve out to see that I had it setup right before putting on the actuator.
