Thread: Aquarite - no power LED
    Feb 2018
    Dallas
    13
    I just noticed that my chlorine is 0 and after a bunch of rain it's time to resolve (diagnostic voltage and amps are both 0). A couple years back (June 2016) I replaced the thermistor on my board and it was totally split in 2. I just went out and removed the cover and the thermistor looks ok - the black casing is not split. I touched it to see if it was loose and the power and generating LEDs came on, but only stayed on for a few seconds before going out again. Is it time to replace the thermistor again?
    12,500 gallons, saltwater/SWG Aquarite T-9, PebbleTec, Aqualink RS-4, Hayward DE filter, built 2000, spa
    Feb 2018
    Dallas
    13
    Re: Aquarite - no power LED
    Answering my own post in case anyone else encounters this. Guessing that the extreme cold stretch a few weeks ago made my very amateurish solder joints on the thermistor fail. Touched up the solder (and re-soldered the red power connection blade - again) and it's back up and running.
    Even with a powerful Weller solder gun, it seems impossible to get the solder to flow just be heating the pin and connection area. Wondering what the trick is...
    Quote Originally Posted by HackerPool View Post
    Nov 2017
    Clearwater, florida
    67
    After my second thermister blew, I just bypassed it by soldering a wire between the two joints. Works like a charm and now I don't have to worry about it failing again.
    30k, 20x40 freeform with spillover spa IG, Pebble sheen finish, Gold line SWG, DE filter, Caretaker in-floor cleaner, Screened in pool
    Jun 2016
    Temecula, CA
    477
    Quote Originally Posted by mitchellb View Post
    That's what I temporarily do in the field when I go crazy troubleshooting a time sensitive equipment!
    Hope you are aware what a "In-Rush Current Suppressor" devices are designed for. Without it, you are bound for a costly repair down the road.
    Anyway, I am not here to condemned your actions but hoping your post will not encourage others to do the same. Amen...
    Oct 2015
    San Diego, Ca.
    825
    I have EXCELLENT results soldering when I mix 1/4 oz. of muriatic acid and 1/4 oz. of water. Use a small brush to swab the only the are to be soldered. It will flow smooth and shinny only on that spot. Spray the area with WD-40 to to prevent corrosion. You'll think your an expert.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
