Thread: Need to fix stamped concrete deck...
    Sep 2017
    Little Elm
    5
    We had our fence re-stained this past year, and the contractor got over-spray all over our stamped concrete pool deck. They attempted to use some mild cleaner on is and in the process stripped out some of the color. So, now I'm left with having to fix the mess and need some guidance. The deck has been in 4 years and not sealed. I sealed it 2 years ago with Deck O Shield, but I think that has pretty much worn off by now.
    My first question (of many, I'm sure), is should I stain the concrete first then seal, or use a sealer that I can tint? Truthfully, for the most part the deck color looks fine, it's just in a few areas where the color is 'thin' looking (the grey of the concrete is showing through).
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,031
    Re: Need to fix stamped concrete deck...
    They say a picture is worth 1000 words. I think this would be a good case for this. Take and share a pic or two so we can really see what you are dealing with.
    Kim
    Sep 2017
    Little Elm
    5
    Here are a couple of pics. In two of them you can see what I'm talking about - where the color has pretty much disappeared.
    Jul 2012
    Tallahassee, FL
    35,031
    Okay I have been thinking on this and asked they hubby what his thoughts were...........we both worry about trying to stain just those areas. The old color has been in the sun for 4 yrs so will be a lot lighter than the new stain.
    Here is our thought--------a light acid wash of the whole area. Rinse it real well and see what you have once it drys. That might even out the color all over. You can then restain or do the sealer with dye in it but I don't really like that idea as I worry it might flake or wear off as sealer does.
    Kim
    Nov 2011
    Moberly,MO
    1,036
    Your best bet contact someone who does a lot of stamped stained concrete and ask for their advice. You could end up doing more damage than good just blindly trying something.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
