Thread: Newbie in Texas
    hahiii's Avatar
    Feb 2018
    Houston, TX
    1
    Newbie in Texas
    Hello all! Trying to get my pool ready for spring and summer. We had a pool at our previous house and just built one at our new home. Just want to ensure I get off to a good start.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Newbie in Texas
    Welcome to TFP!
    A good start is joining this forum! The next thing to do is get a proper test kit. With a new pool managing the water chemistry right from the start will make your summer enjoyable and far more economic.
    Ask your questions in the proper sub-forums.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jun 2017
    Houston, TX
    269
    Re: Newbie in Texas
    Fellow Houstonian here. New pool just finished in December. Buy the TF-100 kit now, start testing before the summer gets here. It takes a few trues but you quickly get used to it. Since the pool has been finished, I've only ever had to purchase the following for maintenance:
    - Muriatic Acid to lower pH due to new plaster
    - HEB Chlorine to raise Free Chlorine (FC) levels when the water was too cold for the SWGC. This will probably go away since the water temp is rising now.
    I've had to buy Cyanuric Acid and calcium chloride as part of my start up process (and salt of course), but I haven't had to get more since the start up.
    I am a believe of TFP for sure.
    Rectangular 24'x40' Salt Water, 4' to 6'. Pentair EasyTouch 8, Screen Logic 2, w/wireless kit. Pentair IntelliFlo VSF Pump, Pentair CCP520 Cartridge Filter, Pentair IC60 Cell, Wet Edge Northshore Tahoe finish. ~28,000 gallons. TF-100 Test Kit. Completed: Dec 2017 Build Thread
    Jun 2014
    17,834
    Re: Newbie in Texas
    Welcome to the TFP forum! Like above, I can't say enough good things about the TF-100 test kit (link below). Great value and will last a good while. I would also suggest getting the magnetic speedstir. It's not a gimmick. That simple item makes mixing the solutions soooooo much easier. You'll thank us. Also, don't forget to update your signature with all of your pool details and equipment so that everyone posting can better serve you. Take a look at all of ours as an example.
    Remember with a new pool (if it's plaster), pH typically shoots-up quickly, so you'll always want some muriatic acid available to keep the pH in the mid 7s. If you manually chlorinate (no SWG), then HEB's regular Bravo or Wal-Mart's Great Value bleaches work very well. Congrats on the new pool, and have a great weekend.
