Results 1 to 15 of 15
Thread: Can I keep chemicals somewhat balanced in this instance?
    Aug 2017
    Frisco, TX
    2
    I noticed this morning that the pool was looking a little cloudy and then noticed the pump had not come on. It maybe has been a day since I remember seeing the water come over the spa ledge. Our pool pump isn't working and the repair guy will be able to come out on Monday....today is Friday.
    Is there anything I can do to avoid algae from forming? It has been raining for days in Texas and I'm a little worried about the pool. I worked sooooo hard last spring to SLAM it and have had no issues since then. If I need to add chemicals, is brushing the walls going to be enough for circulation? Or is it inevitable that I'm going to be SLAMing it again?
    Suzee
    15K Gallon IG plaster with Spa, Centurion 2.0 pump, Pentair FNSP 60 DE filter, built 1993/resurfaced 2015, Polaris cleaner
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Can I keep chemicals somewhat balanced in this instance?
    Welcome to the forum!
    You can just use your brush to circulate the water a bit each day. The cool water does not let things happen too quickly.
    As you state you have SLAM'd before I assume you have a proper test kit.
    Can you add how you chlorinate and your test kit to your signature? Keeps us from asking the same questions over and over.
    Take care
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,883
    Suzee,
    I am curious why you believe that rain will cause your pool to get algae?? I hear this often, but I can't think of why it should have any effect???
    Would appreciate your feedback... I also live in the DFW area and at this point I'm thinking about building an ark..
    I agree with Marty... just using your brush, or your leaf net, should provide plenty of circulation..
    When my pump is off my pool stays crystal clear, so not sure why yours is turning cloudy...
    What are your current numbers???
    FC
    CC
    pH
    TA
    CH
    CYA
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,709
    Last summer a new member with the pool named "the beast" had a broken pump for a week or two. With bleach, brushing, and a robot going 24/7 she kept the 60,000 gallon pool clear.
    Rain only helps your pool, it can flood stuff into it.
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Just do some laps!! I asked a similar question a while back. I think it was Kim that suggested walking around the pool with a boat paddle. Has anyone ever tried that? At least you'd get a good work out!
    12300 gallon IG pebble, freeform 19x28, 1 skimmer, 3 returns, no floor drains, auto fill. Pentair: EasyTouch PSL4, ScreenLogic2, Indoor Control Panel, Intelliflo 2 VST, IntelliChlor IC40, IntellipH, CCP320 Cartridge Filter, MasterTemp 250 Heater, Rebel Suction-Side Cleaner, IntelliBrite. Solar and cleaner actuators. Heliocol HC-50 8-panel solar heating. FlowVis Flow Meter. Taylor: K-2006 and K-1766 Test Kits, SpeedStir. City/softened water.
    Jan 2012
    'burbs of Augusta, Georgia
    8,863
    Brushing, moving the water with a robot and anything else you can manage (sump pump sitting on a step for example) will all help mix chlorinated water around your pool and avoid algae for the most part. Your pool *might* lose its sparkle since it isn't being actively filtered but it should be fine as long as you keep your chlorine up.
    Use liquid bleach if necessary. Keep testing the FC daily.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Aug 2017
    Frisco, TX
    2
    Thanks - you all are so awesome! Everything is in normal ranges with the exception of pH which is 8.2. Can I wait until they fix the pump to treat with muriatic acid?
    Suzee
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Quote Originally Posted by tzutse View Post
    Not sure, but that is a bit high. If it were me, I'd put the MA dose in a bucket of water (5 gal if you got one) and slowly, carefully, dribble it in all around the pool. Then brush to circulate. Others might cringe at that advice, so beware...
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    202
    Just remember never add water to acid, always add acid to water.
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Quote Originally Posted by Alwayswantedapool View Post
    Marty and I are having the same conversation in another thread. He has some alternate advice about adding acid to a non-circulating pool.
    New build in southeast Arizona - Page 3
    I only added what I still remember from my high school chemistry class:
    "Acid inta watta, 'cause that's the way ya aughta."
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,709
    Why can't you add water to acid? I do this all the time to dilute acid for cleaning in the house.
    Casey
    May 2014
    Laughlin, NV
    11,793
    "A large amount of heat is released when strong acids like sulfuric acid and HCl are mixed with water. ... So much heat is released that the solution may boil very violently, splashing concentrated acid out of the container and all this because the reaction is exothermic."
    Very dangerous =========
    Marty
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Quote Originally Posted by mknauss View Post
    Wow. I love TFP. I've been doing this right all along, but for the wrong reason! I was taught that when you pour any liquid into any other, it is the base liquid, the one into which the other is poured, that splashes back. In other words, if you pour acid into water, all those droplets that splash away from the intersection of the two are water. So if you poured water into acid, the splashes would all be acid. I had no idea about the chemical reaction going on. Good on ya, TFP. Thanks Marty!!
    Jan 2012
    8,863
    This is how I learned it also.
    Maddie
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Quote Originally Posted by YippeeSkippy View Post
    Maddie
    My guess is both are true, the reaction and the splash droplets. Either way, ya gotta do it right.
