Thread: ORP Low.......................
    Jul 2017
    Georgia
    2
    Little bit stuck on this.
    ORP says 459 but things elsewhere look good. What am I missing?
    water temp: 67
    ph: 7.2
    salt: 3200 ppm
    total solids: 4700
    CYA: 80
    test strip pic attached too
    Re: ORP Low.......................
    ORP really doesn't work when you have cyanuric acid in the water.
    I would suggest that you get a good test kit.
    Support the site
    Jul 2017
    Georgia
    2
    Quote Originally Posted by JamesW View Post
    I'm using a safedip 6 in 1 electronic to test the ORP.
    I'll have to check with them on that.
    Also, it was the same before I adjusted the CYA levels which were dead low.
    22,760
    How old is your tester?
    Has it been cleaned and stored exactly as the mfg. recommends?
    As JW said above, ORP doesn't work when the CYA is above 20 or 30 ppm. It interferes with the mv value.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Your missing a good test kit.
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
