Thread: AquaCal heat pump
    Jameshtx's Avatar
    Jan 2018
    cypress texas
    81
    AquaCal heat pump
    The designer fr pool company said the heat pump I'm getting is a AquaCal 132k.
    What does 132k means and if this machine is sufficient enough to be compatible with my pool size?
    Completed May/2018 l 17 x 33 IG -Chlorine l 15,500 gal city water l Pebble/Plaster l Jandy 1.5HP FloPro 2- speed pump l Jandy cartidge filter 460 l In-ground chlorinator l AquaCal 132k BTU heat pump l K-2006 test kit w/ speedstir l Dolphin M400 robotic
    Re: AquaCal heat pump
    132 k means 132,000 btu per hour.
    It's ok to extend the season or to maintain a warmer water temperature.
    It's not good for fast heating on demand or for really cold weather.
    Support the site
    Jameshtx's Avatar
    Jan 2018
    cypress texas
    81
    Thanks JamesW.
    Jameshtx's Avatar
    Jan 2018
    cypress texas
    81
    With it having 132k btu, is that okay for a 17 x 33 pool? I see some people having gas heaters with 400k btu and makes me wonder if mine is puny
    Jul 2012
    Cary, NC (Raleigh)
    69
    My pool isn't much larger (at least based on the size you have in your sig) and I have an AquaComfort 75k BTU heat-pump. A heat pump is meant to provide an on-going slow amount of heat and run for a longer time. Versus a gas heater which I would say delivers more heat in a shorter period of time. I could have gone bigger on BTU's but mine is sufficient in conjunction with a pool cover to maintain the pool water temp during the beginning or end of season or help in the early mornings bring it up a few degrees so thats its nice by the afternoon to get into. I'd try to understand a bit better how heat pumps work. But given your in TX seems reasonable to me. If trying to make a big jump in temps over a short time period a heat pump won't do that.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
