Thread: Question about water overflow vent, should it be blocked off?
    Aug 2014
    TX
    40
    So I have this vent right on the side where the skimmer input is, I assume so the pool doesn't overflow when we get too much rain. I noticed its blocked though which i dont understand. Is there any reason i shouldnt take the cover plate off? I am always having to drain my pool in the rain a couple times a year.
    32,000 Plaster Pool
    SWG Hayword Swimpure, chlorine feeder, Triton II 140c sand filter, Filter motor - 2HP VSP
    Decent - 1/2HP motor
    Cannon Jets under diving board - 2HP
    Cleaner Polaris 280 - 3/4HP motor
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,849
    Re: Question about water overflow vent, should it be blocked off?
    dr,
    If it is a overflow drain, it would be odd that it is blocked off.
    How about a picture??
    My overflow has a cover, with slots in it, that lets water pass through.. The bottom of the opening is just above the middle of the skimmer...
    I can't think what else it might be and can't see any reason not to open it.
    If it is an overflow, I suspect it will be connected into your deck drain system... Should be easy to tell with a garden hose..
