Thread: Slight green tint but water balanced and clear
    Oct 2017
    Acworth/ ga
    2
    Tcl 4.7
    cc .2
    ph 7.3
    alk 89
    cya 65
    Water balanced for some time. I did have what I assume was some iron staining back in November and used absorbic acid, which worked well but did give me algae for the first time. This was cleared up in a few days. Now i am left with clear water but there is a very light green tint/ hue. Have tried adding metal magic (proteam) a couple of weeks back and have now run out of ideas. Now under pressure to get some help from a pool maintenance guy. Any thoughts or ideas would be appreciated.
    Johnyboy
    GA - Inground - 15k - plaster - SWG - 2014
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Slight green tint but water balanced and clear
    Welcome to the forum!
    How are you testing your water? Those appear to be Pool store test results. We do not rely on pool store tests.
    If it is a clear green then most likely iron. Search the forum, there are ways to filter it out or sequester it.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
