Thread: How do you clean your tanning ledge/baja shelf?
    Oct 2017
    Franklinton, LA
    55
    How do you clean your tanning ledge/baja shelf? Brush it towards the deeper water for robot or polaris? Vaccuum?
    Ours is 3.5-4 inches deep. Looking for ideas. Thanks
    Imagine Pools Freedom 30 w/Large Splash Pad 12,000 Gallons - IG Fiberglass Shell - Storm Gray color - Pump: Jandy VSSHP270AUT - Filter: Jandy CV340 - SWG: Aquapure 1400 - Controls: Jandy Aqualink - Dolphin M400 - Other: 9 led lights, 3 Jandy bubblers, 5 jets, JE3000TR Heat/Cool Pump - Well Water
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: How do you clean your tanning ledge/baja shelf?
    Brush and manual vacuum. The robot sometimes gets up there but I always brush it towards the deeper water. I manual vacuum every so often so it dies get a vacuum every now and then.
    Matt
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    511
    I just brush it off and the cleaner gets it on the bottom of the pool.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Mar 2015
    Las Vegas NV
    481
    My 16 yo son brushes it and then we run the pool cleaner.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Maytronics Dolphin Nautilus Cleaner
