Results 1 to 19 of 19
Thread: Liner issues
    May 2016
    Richardson, TX
    88
    Liner issues
    Since the leak issue, the last couple days we’ve Had heavy rains and rapidly changing temperatures. The liner now is pulled from the wall in the shallow end and some wrinkles on the bottom. Can this be remedied or am I totally screwed? I think I see a small tear on the seam in the shallow end. Please help.
    https://imgur.com/a/XMCJy
    34K gallon IG PVC membrane - 1.5hp Sta-Rite Supermax VS - Pentair FNS Plus 60 DE filter - 35w 12v LED Color Change Pentair Amerlite / Pentair Globrite Color Change LED - CaliMar Titanium 60k gal SWG - Dolphin Nautilus Plus
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    The liner could be reset with some effort. Some people use a push broom and their feet to help move it. What I worry about is the tear in the seam. I worry that once you start tugging/moving it the rest of the seam will go so use GREAT care. I would triple patch the tear before you do anything else.
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    Quote Originally Posted by kimkats View Post
    Thanks. It's small. I'm going to patch it with Flex Tape like I did the last one. The worst part about this is that I don't even know how old the liner is because we bought this house 3 years ago. It had some patches before we bought it and I put some more on since. It's probably time for a new one, but it's hard to stomach another $3K to replace the liner after just doing a total renovation of the house plus solar panels.
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    A taping you will go!!! Tape it until there is no more tape left in the store!!!!
    Kim
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    So the liner ripped in two spots on one of the floor wrknkles. I think it’s probably necessary for a replacement. Should I drain it all via main drain so it doesn’t continue leaking through the tears?
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    Rock and hard place. You do not want it to leak and mess up your bottom BUT you cannot leave it empty as you risk wall collapses. Any way you can tape the tears on the floor for right now? I would order a new liner ASAP so keep the damage down.
    Kim
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    I put some flex tape over the tears. It may or may not be 100%. I'd assume it's less. Leaking, but not nearly as fast.
    How can I find recommended service techs to call out to replace the liner?
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    First off do you have any good friends that could help you? There a MANY videos that show you how to do it. It is not that hard. Saying that I did pay someone to put my liner in as it was worth it for us.
    Finding some one to put the new on in- Call around to the different PBs and see if they do vinyl pools and who they use for the liner part. Start pulling strings to see who you find. After a while the same names will keep coming up both on the good and bad side.
    Now keep in mind the bottom may need some love. Be ready for that.
    Now for the really fun part-------do you have the paper work from the first liner? It might be hard to figure out who made the pool so it will be some work to find a liner that will fit YOUR pool. It might need to be custom made $$ If you do not have the paper work you might be able to find the "stamp code". Most of the time it is by the steps.
    Kim (no cheering on this one )
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    This pool was built in 1990. I bought the house in 2015. There are no steps, only 2 ladders.
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    Then it will be easy to measure and get a new liner. I would start calling liner companies to find out what info they need from you to order a new liner. That way you will have it when you are ready to replace it. They might even have someone they could recommend to help you measure then install.
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    Had a company come out and this company is the only one in my area who installs 60 ml PVC membranes in residential pools. There doesn't seem to be a lot of info on a search on TFP. Anyone know if it's worth the extra 30%. He said it's virtually impossible to puncture and will last 2x as long.
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    Have not heard of them................hummmmmmmmmmm ask them for a build they did 5 yrs ago and call them to see what they have to say. "Would you hire them again? Would you buy this liner again?" kind of questions will open up some thoughts I bet.
    What is the brand name of this 60ml PVC membranes?
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    Re: Liner issues
    You won't have to measure the liner, if you can find the serial number printed on it.
    Usually found on the shallow end wall areas. (backside of liner)
    If you find that, the manufacturer can make a new one from it.
    Dolphin E10 Cleaning Robot.
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    Kim
    the brand name of the membrane is Elbe.
    http://elbtal-plastics.de/en/swimmin...membranes.html
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    That is a neat idea. PLEASE ask them if they have installed any you can go and see for yourself. I really want to know more about it.
    How is it installed? Are there seams? How are they sealed? I am going to do some more reading to see if I can find the details.
    IF the website is telling the whole story that is some neat stuff there!
    Kim
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    Kim
    It's constructed on site. There are seams and it's welded together with some special heat gun. He's sending me photos, but I don't think he's got authority to tell me I can go some his clients' pools. I wouldn't want random people coming to my house to look at mine.
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    He could give your references that he has asked permission from before hand. Many people do it. I do understand if you are not comfortable doing this though. It is just another tool to use to check your guys work.
    I have done some more reading asking around..........that stuff sounds neat but the chemical level they use are for Germany where they don't use CYA (stabilizer) I would check to see what level of FC (free chlorine) they "allow" if you have a CYA of 50.
    Oh ask your guy how they get it off if need be.
    Here is a thought another member shared with me about this:
    "I’d say the proof is in the warranty. Do they warranty the liner 2X longer than a standard liner? What does that warranty cover? That’s what I’d want to know..."
    I am enjoying learning about this product with you! I hope it works out for you to get it so we can keep learning with you!
    Kim
    May 2016
    Richardson, TX
    88
    Re: Liner issues
    We decided to do the PVC liner, but we’re remodeling the pool at the same time. New coping. Extending out the shallow end to add a splash pad and stairs. I’ll create a remodel post.
    Jul 2012
    Tallahassee, FL
    35,022
    Re: Liner issues
    I am SO excited! Make sure to let me know either by posting on this thread or pm me when you do start the remodel thread! You can make it in under construction. I hope you get LOTS of pics of everything and share them!
    Kim:kim;
