Thread: Side Effect: Sweaty Back After Use?
    Question Side Effect: Sweaty Back After Use?
    I have recently made a connection between my spa and a prolonged wet back. After I use the spa for about 60-90min I take a shower, and I have noticed after my shower my upper back stays wet which I am now realizing is sweat. This only happens when I use the tub and only 50% of the time after I use it. Does this happen to anyone else? I am just a typical healthy late 20s man.
    FC = 3-5
    ALK = 50
    PH = 7.6
    15,000 Gallon Heated Diamond Brite Plaster Pool
    200 Gallon Hot Springs Jetsetter Spa
    Outdoors Partial Tree Shaded Lanai
    Taylor K2006 Test + SpeedStir
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,760
    Re: Side Effect: Sweaty Back After Use?
    How hot is your spa? I'm not a doctor, but my guess is that it's raising your core body temp and it takes a while to drop back to normal.
    Why it only happens sometimes, I dunno. FYI, some medications can also cause you to sweat more than normal.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    104F
    I did do some extensive research on Google that had no relation to a spa but as soon as I related it to a bath bingo everyone in the world seemingly has a sweating problem after a bath according to Google lol.
    I have been using anti-perspirant with a very high level of aluminium lately, maybe it is forced to leave my body from my back since the aluminum blocks the pores under your arms.
