Thread: Pool Placement
    Feb 2018
    OH
    3
    Pool Placement
    I want to apologize if this is not the right place to ask. My wife and I have decided to buy an above ground pool. Where we would like it we had a tree cut down last year in February and had the stump ground down. 1 pool installer said we could not put the pool over top of it. Another said we could. So has anybody else ever been in this situation?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pool Placement
    That ground stump is going rot and decay and give you a sink hole under your pool. I wouldn't put a pool over it with out digging out the soft grindings and filling the stump area with properly compacted fill.
    Feb 2018
    OH
    3
    Re: Pool Placement
    Right that's what I was thinking. The Orange line is where the wall would be. It's our first pool so kinda iffy on placement. Thank you for your time
    Taterfink's Avatar
    Apr 2012
    NE Florida
    550
    Re: Pool Placement
    Quote Originally Posted by FatScott72 View Post
    I had a huge pecan tree removed and the stump ground. We compacted the ground as much as we could. I live in Florida and sand is difficult to compact down. It looks good and solid when it's s damp but it fluffs up when it dries. Anyway, I put 3/4" polystyrene insulation down as a barrier before I set the pool up. Even with all the work done, I do have an ever so slight divet in the center of my pool. I can barely tell. We just call it the "deep end "
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pool Placement
    If you have to put the pool there put the stump under the middle of the pool at least 2 feet from the wall or supports. If you are doing an oval pool you need to stay clear of the pressure plates as well. A small depression under the liner isn't too bad and the liner should stretch to fit as long as it isn't too big. A small depression under or near any part of the frame of the pool and you ask just asking for your pool to fail.
    You are in the cold part of the country as well and that stump area is perfect for some nasty frost heaves and lots of super soft mud in the mud season.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Re: Pool Placement
    Hello and Welcome!
    You didn't mention it, but is this a soft side pool (Intex) or a rigid wall above ground pool?
    If you have the room, I'd suggest putting that stump spot more toward the middle of the pool rather than near the wall area. Dig out the stump area and fill it in with compactable material. The wall area doesn't tolerate settling too well, especially steel wall pools. The liner can then absorb some settling if any.
    edit: repeat info. I guess I should have read the other posts first. lol
