Results 1 to 12 of 12
Thread: Pentair RS-485 connector
    T Man's Avatar
    Feb 2016
    NE, Indiana
    6
    when I closed pool last fall, took off the RS-485 communication cable from the my pump (Pentair intelliflo VS 3hp) and half the pins broke off. this would be off the part of the RS-485 cable that is inside part of the pump, just under the keypad, not the cable that runs to the panelIMG_7984.jpgIMG_7983.jpg... anyone know of where to get replacement besides a dealer? pool stores are still closed around here and they want the entire pump. I have a feeling it's going to take awhile to get/order...
    thank you everyone for your help, this is a fantastic & informative site!
    20' x 50' 23,000 gal vinyl - 42" deep w/ 10' x 20' sun deck - 12" deep w/ Hayward LED Bubblers,
    Chlorinator, Pentair VS 3 HP, Pentair NG 350k BTU heater, Pentair SD 80 filter. Automation, Dolphin Oasis Z5, TF 100
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Pentair RS-485 connector
    Welcome to the forum!
    I would call Pentair technical support. At least get an idea if it is repairable. Then try InyoPools for the part. They seem to be the best at locating parts.
    Good luck!
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    22,760
    You may be able to find one at Mouser or Newark electronics. Put in the number of positions (not just the number of used pins) and see what you can find.
    I'll be surprised if Pentair will sell you just the connector.
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,374
    You could open up the box and hardwire it.
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    T Man's Avatar
    Feb 2016
    NE, Indiana
    6
    thank you for your help! Pentair says I'm IMG_8724.jpgout of luck, I need to purchase a new drive... that's $600! ouch! the inside of connector in the drive is in epoxy (see pic)? so hard wiring or switching out the connector is going to be a challenge if not impossible.
    May 2014
    Laughlin, NV
    11,793
    I was afraid of that.
    You can try a hack job and see if you can hard wire. May or may not work. Worst case, you have to buy a new drive or pump. A new pump (online) is about $1000.
    Take care.
    Marty
    Mar 2015
    Sugar Land , TX
    452
    I would try a Dremmel type tool with a attachment to drill out the epoxy. Dremmell makes all sorts of small attachments that can chip off the epoxy.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,374
    I'd find a way to hardwire it. I can't imagine it is that hard to do. It is low voltage line anyway not sure why they felt the need to have that elaborate proprietary setup for 4 low voltage wires.
    T Man's Avatar
    Feb 2016
    NE, Indiana
    6
    well sorry to say but this problem is still ongoing... deciding not to spend the $600 for a new head unit, I decided to take the advice and direct wire it as we are finally getting our pool opened up. But, here is my problem. I cut into the jacket of the RS-485 line and found only 2 wires (see pics). whereas the connector wire in the head unit has 4 wires... so is it even possible to direct wire this? if so, which wires would go to where? Thank you for your help!IMG_9188.jpg
    T Man's Avatar
    Feb 2016
    NE, Indiana
    6
    sorry having trouble keeping second pic under limit... I did however donate this afternoon but it must take a bit to register.
    the wires on back of pin connector have 4 wires coming off going to the board: green, yellow, grey & red - not sure how this can be hard wired to eliminate the 4 pin connector.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,860
    T,
    The pump only uses two of the four wires...
    The Com port pin 2 green wire goes to the pump connector pin 6..
    The Com port pin 3 yellow wire goes to the pump connector pin 7..
    T Man's Avatar
    Feb 2016
    NE, Indiana
    6
    Worked Perfect! Back in action, thank you!!!
