Thread: When to skim, when to vacuum?
    Klundell's Avatar
    Feb 2018
    Chandler AZ
    47
    Hi! Any advice on how to split time between a vacuum and a skimmer? Currently I run the skimmer on low for 4 hours (will bump that up to 8 when we start swimming). As for the vacuum, from what I under
    stand, it needs to be used on high. The problem is that I have to manually switch the valve from skimming to vacuum. Would you recommend I use the vacuum every day?
    Or can I run the skimmer daily, then only run the vacuum once a week?
    I think the previous owner split the valve so it was half vacuum and half skimmer- would that work? Seems like the vacuum wouldn't have enough power.
    Krys, Chandler AZ
    Pebble Tech Pool / 28,000 gallons
    Triton Fiberglass Sand Filter Model TR60
    Jacuzzi J-VSP250 Variable Speed Pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,833
    Re: When to skim, when to vacuum?
    Krys,
    I have a Robot pool cleaner and not a vacuum pool cleaner, but the basic idea is still the same. I only run my robot about once a week... More if I can see 'stuff' on the bottom of the pool I want to vacuum up..
    I agree that your vacuum cleaner would most likely not run well with a 50/50 split..
    Thanks for posting,
