Thread: New Spa owner and have small white flakes floating on top?
    Feb 2018
    Cardiff/California
    1
    Thanks. I have a 18 month old custom diamond stainless steel spa and for weeks there have been yellowish flakes (algae?) in the water. I have applied copper based algacide, non chlorine shock (renew) but it keeps coming back. Any suggestions are welcome. This spa uses a balboa UV light filtration system. Only peroxide is added periodically. No chlorine because of the stainless steel.
    Brian Jenkins
    above ground (within a wood deck), Diamond Spa, stainless steel, balboa ultraviolet water filtration system, non chlorine.
    Donldson's Avatar
    NW Ohio
    3,250
    Re: New Spa owner and have small white flakes floating on top?
    Welcome to TFP!
    Given that you keep no residual sanitizer in your water it could well be some bacterial problem. The only sanitation happens within the UV chamber, leaving the rest of the water to fester.
    I can't really offer any starting advice other than introducing a sanitizer to the mix. Possibly biguanide or a silver ion source will work. Best of luck!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
