Thread: "Skim-A-Round" Hey! Does anyone have experience with products from this company?
    Jun 2013
    Bowling Green KY
    16
    My wife, bless her outstanding assistance with our pool maintenance efforts while she views her facebook account, has found a company that utilizes "the Bernoulli Effect" in their "new" skimmer baskets. Their products include: (1) replacement skimmer baskets for your in-ground pool; (2) a floating skimmer basket that works off a wall side suction line or one of the existing skimmers and floats around the pool; (3) and their best product (actually referred to as 'the ultimate') that can attach to your robotic cleaner and pull-in surface debris while your cleaner is working on the junk on the bottom of the pool.
    Has anyone actually seen this work or demonstrated?
    I am all-in for something that helps my 15-yr old Mayfair Dolphin Diagnostic 2000 work more easily.
    The website for this company is "www.skim-a-round.com".
    I AM NOT ADVERTISING OR SOLICITING ANY OF THIS COMPANY'S PRODUCTS OR CLAIMS.
    However, I will admit that I am impressed that "Bernoulli" was spelled correctly on their website.
    Thanks for input. If no one has experience with these products, I probably will bite on one. After all, it wouldn't be the most $$ that I have thrown into my hole in the ground since 1986.
    Note: lots of trees and flowering trees and shrubs surround my pool. THANK GOD (OR MAYFAIR) for my Dolphin Diagnostic 2000 and skimmer socks!
    I wish you all a good pool opening!
    SIZE: 20 ft x 40 ft rectangle; 42in- 8ft; 35K gals IG; Install '75; new vinyl liner '97 (liner now bleached white); 1 bottom drain & 2 skimmers (added 1997); MOTOR: 1 HP 1-speed (replaced 1999); FILTER: Hayward Sand Model S-244T (new 2003); VALVE: Hayward Model SP-714-T1 Vari-Flow (new 2012); PUMP: Pentair Challenger Hi-Head ('75); SANITIZER: liquid chlorine bleach - converted to Trouble Free Pool 2013; Dolphin 2000 Robot cleaner (2003)
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: "Skim-A-Round" Hey! Does anyone have experience with products from this company?
    Search for it on the forum. Some have tried it. All have failed to see any reason to buy it.
    Good luck!
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    JoyfulNoise's Avatar
    May 2015
    14,225
    Old & Busted - Teenage child skims the pool
    New Hotness - Skim-A-Round
    Only difference is your wallet is several hundred dollars lighter...
    Matt
    Feb 2018
    Phoenix Arizona
    2
    If you are going to try Skim-a-round products, order thru Amazon not the company itself .. They charge for returns and do not cover return costs either
    Jun 2018
    Michigan
    2
    I just purchased the all-in-one basket. Had to reduce flow through the main drains to get the Bernoulli effect. I have a 40x16x8 pool, and will be curious to see the impact on water circulation. I did receive the product quickly, and am able to use skimmer socks with it. My biggest concern is the effect on circulation at the deep end of the pool with the MDs partially closed. Anyone have experience with this?
    We use the skim doctor on our two skimmer baskets and there is noticeable improvement.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
