Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: Replacing sand in filter
    Lmlduradenali's Avatar
    Jan 2018
    Myrtle beach SC
    77
    Hey guys I have a Hayward 244T sand filter and sand is bypassing so I知 replacing the tree and all the sand....
    So my question is where should I order the sand ??? I want a quality product and I知 having trouble finding so if some one can chime in that would be great . Also I am attaching a photo of my current unit
    Thanks for every ones support and help
    12k Gallon in ground-hayward prologic controller -Hayward S244T sand filter
    Hayward super pump 1.5
    SWG Hayward T-Cell 9
    K2006C Test kit
    dolphin nautilus plus cleaner
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Replacing sand in filter
    No reason to replace the sand unless gummed up by pool store potions or baquacil. If you need to remove it to repair laterals put it in a wheelbarrow or other container.
    If you really want to replace the sand you can buy it at Home Depot or Pool stores.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jan 2018
    Myrtle beach SC
    77
    Thanks! The reason why I think the laterals are messed up, is because I知 getting some sand when backwashing. Here is a picture . Hard to see but multiple pieces of sand. Also my water shoes lots of little particles I assume the filter would catch....
    K2006C Test kit
    Donldson's Avatar
    NW Ohio
    3,250
    Really the only sand we have seen issues with, as far as I know, is the Quikrete sand carried by Home Depot. I think there was some QA issues at one time and some incorrectly sized sand got in to the mix. Otherwise any 20 or 20/40 grade sand should work.
    Don't order the sand online. Shipping on a 50 lb bag of sand costs twice as much as the sand itself does. You should be able to find some locally fairly easily. On top of that, sand doesn't really go bad so if you save the sand you remove you can put it right back in. Give it a good rinse while it is out and it will be good as new.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    May 2014
    Laughlin, NV
    11,793
    The 'small particles' in your water is not necessarily due to sand. As I remember, you do not have a proper test kit and thus are not maintaining this water to ensure it is algae free. It is your pool so do as you wish, but I would suggest that you should give properly managing your pool water chemistry a try prior to blaming a sand filter.
    Sand filter also work best a bit dirty. Be sure you are not backwashing until you see an increase in your filter pressure of 25% above clean pressure.
    Marty
    Dec 2017
    Clinton TN
    13
    Like I said before, sand in the Backwash is nothing to worry about, the water is going backwards through the filter to clean off the top of the sand and some sand is going to get added in. If you have a bad lateral in the filter the sand enters the pool through the returns.
    When you backwash you are cleaning the filter, the fine partials you see in the site glass have been filtered out, that is why they are in the site glass. Also make sure you rinse for a bit to clean out the laterals after backwashing.
    Sand in the backwash is usually due to an oversized pump or there is too much sand in the filter.
    If you're not getting sand coming out of the returns, your laterals are probably ok.
    What pump do you have?
    Support the site
    Jan 2018
    Myrtle beach SC
    77
    Hayward
    Ok I am working on the chemistry now... what all levels should I test and post up
    K2006C Test kit
    May 2014
    Laughlin, NV
    11,793
    FC
    CC
    pH
    TA
    CH
    CYA
    What model/size of pump? A more complete signature really helps. See mine.
    Marty
    Jan 2018
    Myrtle beach SC
    77
    CL 1.0
    PH 7.4
    TA is 220 which is high high
    K2006C Test kit
    May 2014
    Laughlin, NV
    11,793
    Those results are from a true test kit, not strips? What kit do you have?
    Please update the signature.
    Marty
    Jan 2018
    Myrtle beach SC
    77
    Test was wrong
    TA is 60-80
    K2006C Test kit
    Jan 2018
    Myrtle beach SC
    77
    Quote Originally Posted by mknauss View Post
    I believe so and not text strips
    I知 trying to update signature now
    K2006C Test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    10,018
    Quote Originally Posted by Lmlduradenali View Post
    CL 1.0
    PH 7.4
    The FC is meaningless without the corresponding CYA reading. But, with that being said 1.0 is low unless there is no CYA in the pool.
    The test kit you have simply does not provide the accuracy and consistency you need. It is missing the required CYA test and the FC test is a color match OTO te4st limited to 5FC.
    Order a TF100 or the only other real option for a test kit is a Taylor K-2006. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. You need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    Support the site
    May 2014
    Laughlin, NV
    11,793
    Your test kit does not have a FAS-DPD test for FC and CC. You also need a test for CYA.
    I strongly suggest getting one of the two test kits the forum recommends. The Taylor K2006C or the TF100. I have the TF100 from TFTestkits.net.
    I suggest you get one too.
    Take care.
    Marty
    Jan 2018
    Myrtle beach SC
    77
    Ordering now
    K2006C will be here Tuesday!
    Sounds great and I just want to thank every one!
    K2006C Test kit
    May 2014
    Franklin, NC
    10,018
    Ordering now
    While you are waiting for it to be delivered, how much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Support the site
    Jan 2018
    Myrtle beach SC
    77
    Thanks guys
    also updated my signature as well
    Once again y誕ll are being so helpful! Thanks
    K2006C Test kit
    Jan 2018
    Myrtle beach SC
    77
    Taking about why I worry. My cleaner just finished and it was perfect. Now I look and see garbage at the bottom:/:/
    K2006C Test kit
  20. Back To Top    #20
    May 2014
    Laughlin, NV
    11,793
    Good start on the signature!
    What type of pool surface do you have? Fiberlgass, gunite, vinyl?
    I thought you said you had a SWCG? If so, please show the model and size.
    Be sure you ordered the K2006 C. The regular K2006 has very small amounts of testing materials, especially for the tests you do the most, FAS-DPD and CYA.
    Marty
