Thread: Hello! I'm a new pool owner and need some info.
    Feb 2018
    Florida
    1
    Hey! I recently moved to a place with a pool, and we have a pool guy helping for now. However, I want to know what poles, skimmer nets, and vacuums are all compatible. I also want to know how to use a canister, does it come with another piece of tubing so it can work, or do I need to buy more?
    What pole works with this net: https://www.amazon.com/Pool-Net-Leaf...mer%2Bnet&th=1
    and what other accessories like vacuums will also work with its pole? And what tube should I buy for my vacuum? What canister will work with that tubing? Also, would it be better just to buy multiple poles? I also have a fiberglass pool, so what brush will work for it and what poles work with it?
    Jun 2014
    17,795
    Re: Hello! I'm a new pool owner and need some info.
    Hello and welcome to TFP! Being so new, I'm sure have tons of questions. You've come to right place. Just be patient because some of this may seem new to you. I'll try to get you going with some key points:
    - Like you, I have a FB pool. Generally we're advised to use a brush with nylon bristles as they are strong enough to clean the pool shell without damaging the gelcoat.
    - Please update your signature with all of your pool info. You can go to "Settings" and update signature from there. You can see mine before as an example.
    - The link you provided is a popular net that scoops well. I have something similar. As long as you have a pool pole, many of those nets are interchangeable, so just find something you like.
    - For vacuuming, we'll help you more when we know the type of equipment you have. Also let us know if you have just a poolside skimmer or also have a main drain.
    - Do you have a dedicated pool cleaner suction or pressure port, or will you be manually vacuuming?
    - Lastly and most importantly .... how are you testing your water? That will be priority #1. If you say the pool store, please reconsider obtaining your own TF-100 (link below) or Taylor K-2006C. Those are the only two kits we recommend here for accurate home testing. It's not hard, and the rewards far outweigh putting it off.
    Let's start with that and we'll all chip-in to help you. Nice to have you with us.
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,366
    Most pool poles, nets and brushes are standard sized. I got the below and it is great.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,366
    FYI I don't like that net because of the metal frame. I think it will scratch the plaster. I got a plastic one that has a unique design to help funnel leaves to the net.
