Thread: New system
    New system
    Hi,
    At the point of all the original equipment needing replacement. Currently have a one hp superpump and salt system that I need to replace. I also need to replace the plastic ball valve for the waterfall since the handle has broken off. I was thinking of putting a varialbe speed pump in and an electric valve with actuator for the waterfall. I saw Jandy has a iQPUMP01 but that looks like it only will allow smartphone control of the pump and not a valve. I like the idea of smartphone control of the pump and was wondering what the other options that are economical to control the valve wirelessly. My old salt system just runs when the pump is on which works ok so I was hoping not to have to put a control panel in for the new system just for the need to control the actuator but don't know if that is possible. Thanks
    12000 gallons
    Sand filter
    Inground
    hayward super pump 2 - 1hp
    Dave
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: New system
    Sounds like a project!
    To achieve automation of a waterfall and SWCG and Pump, you are best to get pump, SWCG, and automation system from one manufacturer. The major ones (Pentair, Jandy, Hayward) all have systems that can achieve your needs.
    For instance, a Pentair EasyTouch with IC40 SWCG and Intelliflo VS pump will provide what you wish to do with one actuator for your waterfall.
    Do not get 'Lite' versions of the automation.
    Some manufacturers warranties are based on having their equipment professionally installed. So be aware of that. Equipment cost only of the above will be $2500-$3000.
    If this sounds interesting we can guide you to more specific model numbers, etc.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Re: New system
    Looks like to control the waterfall, that would require the pool controler and be around 1k, I think that is more than I want to pay just to divert water to the waterfall automatically. So what size variable speed pump should I replace my 1hp single speed pump with?
    12000 gallons
    Sand filter
    Inground
    Dave
