Results 1 to 17 of 17
Thread: How much Sodium Bicarbonate do you put in your pool, month to month?
    Mar 2015
    Huntington Beach/CA
    11
    How much Sodium Bicarbonate, Sodium Hydrogen Carbonate, or Alkalinity Up (referring to same thing: Baking Soda) do you put in your pool, month to month, or throughout the year?
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: How much Sodium Bicarbonate do you put in your pool, month to month?
    Zero.
    Never need it. My fill water has more than enough alkalinity in it.
    Also, pH-Up products are almost exclusively soda ash (washing soda or sodium carbonate). Alkalinity-Up products are baking soda. Typically speaking, alkalinity raising chemicals are unnecessary unless you have acidic fill water (low TA and low pH) and/or you use acidic chlorine sources (trichlor/dichlor).
    Matt
    Saturn94's Avatar
    Mar 2015
    Virginia
    583
    I only need to add it maybe once a season to bump TA up a little.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 w/booster pump/Hayward Superpump 1 hp/city water/Taylor test kits/pool installed March 2004
    mdogan's Avatar
    Nov 2017
    Frisco,TX
    96
    i never had a chance to use since mostly PH goes up and use MA.
    If you asked question as MA, there could be 100s of reply
    12000 Gallon In ground Pool with Spa Spillway. 32X18 Free Shape Pebble Finish.
    Hayward 2.4 Hp for Pool + 1.5 hp for Water Fall, Hayward DE6020 filter, Hayward H400 Heater(Gas).
    4+1 Main Drains / 6 Returns / 2 Skimmers. Taylor 2006-C Test Kit, M500
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,705
    0, over 200 ta fill water.
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Mar 2015
    Huntington Beach/CA
    11
    Zero.
    Yeah, fixed that typo. I realize it depends on fill water mostly. I just was curious as to on average what amounts people here find they use.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Do you have a test of your fill water? pH, TA, and CH.
    I assume you have a proper test kit?
    Can you add a signature? See Pool School - Getting Started
    How do you chlorinate your pool?
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    If you use trichlor, you will need about 1.14 lb bicarb per lb of tabs to compensate for the TA and pH drop. That's about 0.5 lb per 7 oz tab.
    Other than that, you shouldn't need to add bicarb on a regular basis.
    Support the site
    May 2015
    14,225
    Quote Originally Posted by JamesW View Post
    Thanks for the quick rule-of-thumb James!
    Matt
    Mar 2015
    Huntington Beach/CA
    11
    Quote Originally Posted by mknauss View Post
    Yes, using the Taylor Alkalinity test with a Speedstir. Really the only way to do it accurately.
    May 2014
    Laughlin, NV
    11,793
    I was looking for what test kit you use. Not just for alkalinity. A signature would help us help you.
    Take care.
    Marty
    Mar 2015
    Huntington Beach/CA
    11
    Take care.
    I use a variety of test kits depending on the situation. Mostly Taylor for accurate tests. My goal is LSI of zero while keeping all parameters within recognized standards.
    What chlorine do you use?
    What is your fill water TA?
    What pH are you targeting?
    How much bicarb are you adding per week?
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,162
    Since the TA is a buffer to pH, there really wont be an across the board average either on how much to add, how often or whatnot.
    The best TA level is the one which keep your pH stable for the longest period of time. so its going to vary considerably.
    Divin Dave,
    May 2015
    14,225
    The Huntington Beach Water Quality report from 2017 (see HERE) inidcates a TA of anywhere from 126ppm to 155ppm with a CH value between 50-70ppm (wow, how nice to have such low CH fill water!!). The pH is on the high side at 8.0-8.1. If one were using pH neutral forms of chlorine (chlorinating liquid or an SWG), then no bicarb additions would be necessary and one would likely being using muriatic acid regularly to keep the pH and TA in check. The fill water would already have a CSI value close to zero so not much acid would be needed.
    Matt
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,540
    For me, it's zero.
    Our fill water has TA of 50, so there's ample incoming TA normally.
    One day in 2016, we got a really big rain (>7") that dropped my TA by 30 ppm and happened to be helpful with high TA at the time. If I had already dropped TA down to 50 or 60, then I might have needed to add some, so I keep three pounds of baking soda in stock (which is still there).
    I could also use that if I ever had a warranty claim / service call and needed to bump my TA up to 80 ppm to be in line with an equipment manual temporarily.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,188
    Just checked mine on Saturday. TA is 40 and ph is 7.5.........I target a TA of 50 in the summer and haven't added a thing since September. Seems to be my sweet spot for ph. I usually have to add 4 or 5 boxes of baking soda by the time the season rolls around after all the winter rain water and draining down and such.
