Thread: do eyeball returns need thread tape
    Feb 2017
    Tulsa, OK
    116
    I recently had a leak fixed in my pool and when the repair guys put the return eyballs back in they did not use thread tape. However, I can see that there was thread tape there before. Should i take them back off and put thread tape around the grooves?
    Also, they left one of them about 1/3 of the way unscrewed. Do they need to be screwed tight to the wall?
    Thanks
    Tulsa, OK,Gunite inground pool - lagoon finish - 20,000 gallons
    Hot tub in one corner that is raised about 3 feet and has two spillovers into the pool
    Small side pool with two pipes that jet up water and has two spillovers into the pool
    Has a sundeck at the front
    31,199
    Re: do eyeball returns need thread tape
    No need to waterproof that joint really. I would skip the tape.
    1/3 of the way unscrewed would bother me......can you snug it down?
    Feb 2017
    Tulsa, OK
    116
    Ok, I wont bother with the thread. Yes, I can snug it down. I will just have to take the top off and then adjust the eyeball and screw it in with the channel locks.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Teflon really helps when you take it out the next time.
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    31,199
    Quote Originally Posted by cfherrman View Post
    That's a good point. No need to waterproof it but the lubrication teflon provides would be helpful
