Results 1 to 7 of 7
Thread: Doheny Discovey Issue- Unit starts then stops immediately
    Mar 2017
    Petaluma, CA
    14
    I am having an issue with my Doheny Discovery / Dolphin S200, which I wanted to see if anyone has experienced.
    The unit is just less than a year old. Recently it stopped working properly. When started from the power supply, it will start forward 1-2' for about 5-10 seconds and then just stop. I did some troubleshooting:
    -I just opened up the impeller looking for hair and debris, including removing the fan blade where it enters the metal shaft, all looked clear.
    -Checked all side and bottom ports, those look clear.
    -The basket is clean
    -The tracks appear to be on properly and can be rotated by hand with the unit off, with what feels like normal resistance.
    -I took the unit out of the water, unplugged the power supply for an extended period, and checked the cord for damage. All looked fine.
    Anyone else experience this issue or have any other troubleshooting suggestions?
    It has been a great cleaner so far, much better than the older generation Dolphins we had. It has a 2 year warranty, so I guess that is the next step in the process if I can't get it working.
    Thanks!
    Mike
    1960 18x36 In-ground Plaster 'MacGyver' Pool
    30,000 gal with significant water loss, blue chipping tile
    Suction line installed on top of pool deck -> Pentair Intelliflo VS, 2"->
    Pentair 520 Cartridge Filter ->Pentair inline chlorinator
    Doheny Discovery Pool Robot
    Mar 2017
    Petaluma, CA
    14
    Re: Doheny Discovey Issue- Unit starts then stops immediately
    Just took everything apart again to see if I missed something, plus took both rubber tracks off, checked for obstructions and reinstalled- no luck, still same behavior.
    JoyfulNoise's Avatar
    May 2015
    14,225
    There are other threads with similar symptoms. All Dolphins have a startup sequence and yours seems to be detecting an error and stopping. You checked all the obvious issues so it points to a possible motor issue. You canít repair the motors, if they go bad they are simply swapped out with new ones. Start the warranty repair process, thatís your best bet.
    Matt
    Jul 2017
    Massapequa, NY
    302
    Can you turn the impeller by hand?
    Aqua Products Certified Premier Service Technician, Maytronics Elite Service Technician, Hayward Authorized Robot Technician. I also dabble in pump, filter, and automotive repair.
    Need help choosing a Dolphin? Check out my thread on the features of each model.
    Feb 2016
    Fort Mill SC
    50
    Had same issue, motor swapped under warranty, no further issues. Cleaner is back in pool running great!
    Tega Cay, SC
    2016 build 16x32 polymer IG-Speck BaduMV 2.4 hp variable speed pump-individually run 2" plumbing-4 returns-1 skimmer-Doheny Discovery robot-
    jetted bench-Pentair Clean and Clear Plus 420 cartridge filter-Circupool RJ60+ SWG-Hotspot FPH heater
    Mar 2017
    Petaluma, CA
    14
    Yes, the impeller and directional pivot both move by hand. The unit moves in the start up routine, so as others have suggested, probably some motor issue. Waiting to hear back from Maytonics.
    Mar 2017
    Petaluma, CA
    14
    Sent the unit back to the Maytronics service center- 2 days and $50 to Fedex from CA to AZ. They dropped a new motor in it and shipped out the same day it was received. Two days after that it was back in the pool and working normally.
