Results 1 to 11 of 11
Thread: Which type of roof fan or venting should I use? turbine, down-draft, or up-draft ?
    Jan 2017
    Muscatine IA
    12
    We moved into a house a couple years ago with an indoor pool and hot tub area. There is a FanTech updraft fan at the peak of the roof and another spot where a 2nd fan was removed at some point. It is a 12 inch opening and I would like to put in something when we redo our roof in a couple months. The fan that is there seems to be a down draft model, but wouldn't I definitely want an updraft model if I am trying to get heat out of the building mostly in the summer time? It runs on a temperature switch and during the colder months I wouldn't run it at all of course. We live in Iowa.
    Dan from Muscatine Iowa
    Inground Indoor Pool- 10x30 Plaster 13000 gallon, Trane 400k Nat Gas Heater, Pentair SuperFlo 3/4 hp pump, Pentair SD60 Sand Dollar filter
    Inground Indoor Hot Tub- 900 gallon kidney shape, 200k Sta-Rite Nat Gas Heater, Hayward Star Cartridge filter, Hayward Super pump 1 hp
    JoyfulNoise's Avatar
    May 2015
    14,233
    Re: Which type of roof fan or venting should I use? turbine, down-draft, or up-draf
    Does the make-up air for the room come from the outside? Is there an independent HVAC system for the room or does the room just get its environmental control from the rest of the house?
    Indoor pools always present a complicated air-handling scenario - it all depends on what you want and how much you’re willing to spend. Have you ever, or would you consider, calling in an HVAC company for a consult? Pool rooms are a special beast so you’d need/want someone with experience in that.
    Matt
    Jan 2017
    Muscatine IA
    12
    The area doesn't have any air temperature control besides some skylights we can crack open in the warmer months and these fans. I originally assumed the fans were blowing air up and out of the roof but when I look for these online I find ones that look exactly the same and they are described as down-draft. My roofing contractor is willing to deal with fans but I was wondering if there would be a usual rule-of-thumb on fans like this in a pool area. I live in Iowa so the local HVAC places probably wouldn't have a lot of dealing with indoor pool areas but I wish they did.
    This is what I have currently-
    Products | www.fantech.net
    And this is what I am thinking I should have instead, although I don't like the "cup" shape that looks like it would fill with water on my roof. How is this a roof fan?-
    Jan 2017
    Texas Hill Country
    145
    Is there any sort of venting down lower that draws air in?
    25k IG / Plaster / Built Jul'16 / Spa with Spillway into Pool / Originally filled with trucked in city water, maintaining level with rain water / Polaris 280 Sweep / Jandy Pro Series EPump a& CV 580 Cartridge Filter / Aquacal Heat Pump / AquaLink Control Panel w/PDA / TF-100 Test Kit / 2 Yellow Labs swimmin' all the time
    May 2015
    14,233
    Well, here’s the thing - even though it sounds counterintuitive, at a fixed temperature, warm moist air is less dense than warm dry air. So one would expect the humid air generated by the pool to rise and, if natural air flow exists, it would go out the skylights.
    The question is one of make-up air and where you get that air from. Is the fan intended to supply the makeup air or is it intended to exhaust air in the room? Are there any windows, doors or passive vents to the outside?
    Maybe a sketch of the room would help...
    Matt
    May 2016
    West Bloomfield, MI
    773
    My fan exhausts. It's manual and variable-speed. Make-up air in my house comes from a large vent in the utility room. I wish the flue for the pool heater in that room could be fitted with a heat-exchanger to heat the replacement air, but as it stands, the running pool heater helps off-set some of the cold incoming air. I use my pool exclusively in the winter. I keep the pool covered when it's heated, and I keep the fan running while swimming. That strategy mitigates moisture issues very well, but at the (literal) expense of sending tons of hot moist air outside in winter.
    I've found that swimming when the temps are single-digit or below isn't worth it. No matter how warm I get the pool water, cool air hitting us in the face isn't pleasant.
    I'm curious about your heater. My pool isn't much smaller than yours, but my heater is a 200 compared to your 400...!?
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Raypak 206 NG heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    May 2015
    14,233
    All heaters will use the sane amount of energy to heat a specific volume of water, the only difference is how fast it can do it. My MasterTemp 400 was only a few hundred dollars more than the next smaller model when we built the pool so it just made sense to go big. It’s very nice to be able to heat the spa in 20-30mins.
    Have you considered using a large room dehumidifier in the winter to try to control humidity? The output would be warm dry air and condensate water. The condensate could be directed back into the pool or down a drain. Definitely would cost a pretty penny to run that but it might be better than sucking in frigid air
    Matt
    Jan 2017
    Muscatine IA
    12
    Yes I forgot to mention there are casement-type windows that I can tilt out all along the lower perimeter of the area.
    Quote Originally Posted by salty87 View Post
    Jan 2017
    Muscatine IA
    12
    Here are some pictures of the area it is an L shape with pool on one end and hot tub on other-
    Jan 2017
    Muscatine IA
    12
    I don't worry about the colder months as much, I just close all windows, skylights and keep the roof fan off. I am more worried about the warmer months when the ceiling surely gets insanely hot.
    The house came with a 150k old Hayward and it wasn't heating fast enough except basically when you don't need it in July and August. The house came with a 415k nat gas supply and once I saw that I decided to go with 400k for the pool and 200k for hot tub. I am careful not to run anything else nat gas while the pool heater is running though. I bought these heaters on Amazon and they were only 1400 for the Trane and 800 for the StaRite.
    Quote Originally Posted by Rollercoastr View Post
    Yes, bigger is nice now that I have these new heaters. I can raise the pool temp 1 degree every 22 minutes and the hot but one degree in less than 2 minutes.
    Jan 2017
    Muscatine IA
    12
    I have slowly but surely gotten the humidity figured out in our first couple of years. If I crack open a few skylights and crack open some of the casement windows down low I keep moisture under control pretty well.
