Thread: Check a newbie's numbers please
    Jan 2018
    Muskoka
    7
    CH: 260
    TA: 120
    pH: 7.4
    SI: ~= 0.15
    Bromine: 4ppm (3.825-4.05 ppm)
    I believe the above parameters are balanced and good to go, and now I just have to tune my bromine setup to maintain ~2-4ppm or more while away from the tub.
    Longer story: I drained and refilled my tub on January 27th, but did not at that time have time to balance the water. I adjusted CH using test trips to ~200ppm but that's as far as I got; and left it with enough bromine to last a week which is when I was supposed to return. I didn't actually return for 20 days; last night, I tested bromine with a taylor kit and got a value < 1/4ppm, but not zero. I shocked the spa, and after 4 hours the bromine level was still 20ppm. I used X-it to lower the bromine so that people could use the tub with the reading at 6ppm, though this may have been false as I haven't figured out what's in the shock I used (and if it's non-chlorine shock, the taylor kit indicates that it is not accurate for bromine while the shock is active). This morning I adjusted TA, tested pH, and added bromine granules to bring the bromine from 2ppm to 4ppm.
    Criticism welcome. Validation that the test parameters I have now are good would also be very helpful.
    Thanks!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,036
    Re: Check a newbie's numbers please
    I know nothing about spas but here is a link TFP has about them:
    How do I use Bromine in my spa (or pool)?)
    I hope this helps.
    Jan 2018
    Muskoka
    7
    Thanks for trying to help, kimkats. If you review my other posts you will see that I have both read and resummarized that post already.
