Results 1 to 9 of 9
Thread: Looking for plaster contractor in atlanta
    Mar 2016
    Marrietta Ga
    82
    Anybody know or can recommend one? Mine is 7 years old and didn't hold up as well as I had hoped.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,012
    Re: Looking for plaster contractor in atlanta
    7 years??? OUCH! Let me ask you some questions. When you say it "didn't hold up as well as I had hoped" what do you mean? What is wrong with it? Have you tried anything to "fix" it so far? I see you have been on TFP since March 2016 so guessing you had the plaster for 5 yrs before you found TFP so...............not sure how far gone the plaster is. We might be able to save you some $$$$$$ if we have a go at it.
    Kim
    Mar 2016
    Marrietta Ga
    82
    Has a couple cracks at the top so thinking I can fix them...Last time I filled it I used test strips for cya and added too much before I bought the test kit
    Any suggestions to seal 2 cracks about 2' long but not wide or deep.
    Jul 2012
    Tallahassee, FL
    35,012
    Here are some ideas I found when doing a search:
    https://www.amazon.com/s/?ie=UTF8&ke...l_7uy5wfbsbd_e
    I don't know if they work like they say so will leave that to you.
    Do the cracks leak? Are they under water? Do you have a clue what caused them?
    Mar 2016
    Marrietta Ga
    82
    They are small go can't be leaking a lot of any. I think what cause them was water was getting in between the tile and the pool deck when it rains and pushing behind the tiles causing them to stay wet and fall off and I fixed that when the deck was redpne last year.. I read some folks used JB weld and I even thought about gorilla glue. It expands when wet, I patched a 1/8 wide crack in my basement wall years ago and stopped the leak and held up..I squirted the glue on and covered with duct tape to make it expand in and not out.
    Mar 2016
    Marrietta Ga
    82
    Any idea what this black / brown spot is in the bottom of my pool
    Apr 2015
    tucson, arizona
    1,405
    Re-Bar Bleed through, you might want to first get an idea what kind of surface you want and then contact manufacturer to see who in your area applies it
    Mar 2016
    Marrietta Ga
    82
    Hoping to put it off couple more years. I don't think the last guy did the plaster knew what he was doing
    Mar 2016
    Marrietta Ga
    82
    Between all the cracks and the re-bar I am going to get it redone PLus for every tile I fix 2 fall off.
