Results 1 to 14 of 14
Thread: What the heck is this thing on my pump????
    Oct 2017
    Austin, TX
    5
    Hey,
    There is a tube coming out of my Jandy Stealth pump which looks like it is where the drain plug should be and the tube is dripping water out of the other end.
    Does anyone know what this is and why it is there? I can find it on any diagrams of the pump online.
    Thanks so much👊👊👊
    Britton Harris
    Spicewood, TX
    Jun 2016
    boiling springs, SC
    99
    Re: What the heck is this thing on my pump????
    sounds like a drain tube but if you could post a pic it would be easier to tell.
    23,000 in-ground salt water pool with liner, 1.5 HP 2 speed Pentair pump, Hayword C4025 cartridge filter, Jandy SWG.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,872
    Britton,
    A pic would help, but I suspect it is for an Ozone system.. Maybe the Ozone system has been removed or the tube has come loose?
    How old is the pool??
    Oct 2017
    Austin, TX
    5
    Thanks for the replies guys here are some pics of the tube in question921208F1-4F85-44DC-BDE4-A09AB2C339C4.jpg
    and this pic show the end piece thatwas originally attached with the screw in the end25FC3D4A-6296-47C3-A394-338D3D1A57D8.jpg
    Thanks again for the help identifying this.
    Britton Harris
    Spicewood, TX
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    Ya probably for a tab feeder or something.
    I did the same when I removed my tab feeder, just turned a screw about 1/2 an inch with some
    liquid nails glue inside and a small hose clamp to keep it water tight.
    Dolphin E10 Cleaning Robot.
    Oct 2017
    Austin, TX
    5
    The other end of the tube connects to the pump, what is a tab feeders purpose
    Britton Harris
    Spicewood, TX
    May 2017
    Coventry, CT
    335
    I've seen some type of small liquid chlorine dispenser that hooks into the drain plug of the pump basket. It was a small (maybe 3"x3"x1") clear plastic device that just used the vacuum side of the plumbing to drawn in liquid chlorine. there was also a small knob on it to adjust flow, maybe it had a one-way valve as well, I'm not sure, I didn't buy it and got a Rola-chem instead. For the life of me I can't remember the name of the device and can't find anything like it with google.
    Maybe a previous owner removed the drain plug to hook up something like that, then lost the drain plug and later decided to do something else so just plugged the tube with a bolt.
    Quote Originally Posted by Cinco10984 View Post
    A tab feeders purpose to feed chlorine into the pool via 3" TriChlor pucks. You won't ever want to use one anyway, so if it was going to a tab feeder be glad it's gone.
    20' X 40' IG vinyl lined; 31,300 gallons; built ~30years ago
    Hayward 1HP Single Speed Pump w/Sand Filter
    Taylor K-2006,Rola-chem sodium hypo feeder/ 15 gallon tank
    Fill from soft/neutral well water, low flowrate well pump
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    Demegrad I think your talking about a stenner pump. (for liquid chlorine injection)
    May 2017
    Coventry, CT
    335
    Quote Originally Posted by borjis View Post
    Definitely not a stenner pump. Stenner pumps are peristaltic pump which create positive pressure to force chlorine into the pressure side of the system. This thing I saw at a local pool store (where I later bought the Rola-Chem pump from) was much smaller and simpler but it works solely on pressure differences, thus the chlorine injection line must be installed on the vacuum side of the water pump to suck in the chlorine.
    May 2017
    Coventry, CT
    335
    Finally found this stupid thing. Where you'd normally pipe in a Stenner pump as close to the pool return as possible, this thing must be on the suction side.
    Pool Pal Liquid Chlorinator
    https://www.poolpartsonline.com/p-35...lorinator.aspx
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    Quote Originally Posted by Demegrad9 View Post
    Whoa! That's kinda neat. Had no idea those even existed.
    May 2017
    Coventry, CT
    335
    There's some old threads on this Pool Pal thing. Yes, it's certainly simple and relatively cost effective but there's a few concerns 1) as to whether you'd be able to get enough fine tuning of chlorine, 2) corrosion of the internal stainless steel plate (which they might have changed to a different material), 3) maybe it's not the greatest thing to be injecting chlorine then have that high concentration water go through your whole system. It's usually recommended to inject chemical at the last point in the system.
    Houston, TX
    1,371
    quote by Demegrad: "It's usually recommended to inject chemical at the last point in the system."
    Absolutely. When anything that is concentrated or builds concentration while the pump is idle, when the pump first starts and sends almost any vol of hypochlorous acid in concentration, it can really wreak havoc on metals. Plus, if it leaks while not being stored, it can really cause problems...that's why it's on the down end of the return line back to the pool to go into the return jets...
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    wow and in the old setup i got when I bought my house 2 years ago, there was no check valve to
    prevent the tab feeder seeping concentrated dissolved tabs back into the heater.
    Glad I removed it / don't use.
    Heater was replaced last year so it never got exposed like the previous one had.
