Results 1 to 18 of 18
Thread: Discolorations on plaster
    Jan 2018
    Chino hills, CA
    63
    I'm trying to figure out what is going on here. We had the plaster acid washed when we moved in to get rid of. Black algae. We had other repairs made including a rusty piece of rebar. It appears near the drain I'm getting black spots. Some are linear which makes me wonder if that is more rebar issues. The side walls have a yellow/grey type tint. You can see it is up and down like where the acid was poured and scrubbed. My neighbor gave me dry acid and told me to let it sink to the bottom in a sock to help get rid of it it. I havent had a chance to try it yet. This weekend.
    My levels are always with in acceptable range. I keep the PH on the low end around 7.2 as it is always rising. FC I aim for 10 and dose 10% bleach and MA daily 8oz of each to keep everything in check.
    Im not sure now to investigate or fix this.
    Thoughts?
    10k pool
    Pentair 4000 DE filter
    Century Centurion 1hp?? Pump
    Hayward Navigator Cleaner
    Mastertemp 400
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Discolorations on plaster
    How do your test your water chemistry? Do you have a full set of test results?
    Acid wash does not eliminate algae. But, I would suspect that it would erode plaster that is older such that more rebar may show through.
    I would delay on the powdered acid test. We recommend using a chlorine tablet to test for organics. Is that what you were doing? Acid is not used to test for removing a stain from anything.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jan 2018
    Chino hills, CA
    63
    I have the k2006 test kit.
    I'm not familiar with the tab testing.
    Neighbor said the spot should go away in 12 hours. Not really sure what it reacts with.
    10k pool
    Mastertemp 400
    Jan 2018
    Chino hills, CA
    63
    Fc 8
    Ph 7.4
    Alk 80
    Calc 260
    Cya 70
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    Thank you on the test results. Look good to me.
    I would never place dry acid in one spot on a plaster pool for any amount of time. I would stress please do not do that.
    What are you trying to remove or test for?
    Marty
    Jan 2018
    Chino hills, CA
    63
    Quote Originally Posted by mknauss View Post
    I'm not sure where to start with the black dots forming on the bottom on the bottom. I'm not sure how to start troubleshooting.
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    You mentioned black algae before. Was it in that area too? Black algae has a specific process to remove, see Pool School - Black Algae. It can be problematic to eliminate as the roots can get deep into plaster, especially older plaster that has been eroded due to maintaining water with parameters with a CSI of below -0.6.
    Do you monitor CSI? Your test results above are in the OK range but with any lower pH you would have aggressive water chemistry.
    If they are iron stains from rebar, you will not remove them. They will be reoccurring and it is time to recondition the pool surface.
    Marty
    Jan 2018
    Chino hills, CA
    63
    What is CSI? I'll read up on the black algae removal. You would think that the acid wash would have done it. It was completed the first week in January. Would it start to resurface already it the chlorine was maintained correctly. What else would cause the black spots? What about the weird yellow brown wavy discolorations
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    Chlorine is needed for algae removal.
    Black algae can be chlorine resistant. Read the Pool School article. Your FC you listed is not all that high based on FC/CYA Chart.
    The discolorations do not show on the pictures. The colors you state could imply algae. Have you done an Overnight Chlorine Loss Test lately?
    How do you chlorinate?
    Take care.
    CSI -- Calcite Saturation Index - requires pH, TA, CH, CYA, Temp, uses Borate, Salt
    Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools.
    Marty
    Jan 2018
    Chino hills, CA
    63
    I use liquid, 10%.
    Once it dips to 8 I dose it back to 10, which I believe is the upper range?
    I read the article. It references acid can discolor plaster. Wonder it that is the cause. I scrub the side walls pretty hard I would think it would knock algae off, but im pretty new to this. I did hurt my back 3 weeks ago and have not scrubbed like I had before. I'm wondering if that is the cause. Finally back on the mend and can get going again. I think that's why I noticed this.
    I'll do the OLCT. Never done it before, but read about it. Also I'll research the CSI test procedure.
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    CSI is not a test. It is calculated by using PoolMath. See link at top of page.
    Marty
    Jan 2018
    Chino hills, CA
    63
    Ill check it out. I don't see it on the app. I'll try the website.
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    It is shown on the app. It is automatically calculated as long as you have data for it. Look at your Logs. It is the last item in each log.
    Marty
    Jan 2018
    Chino hills, CA
    63
    I've never been able to save the data on the app. Do I have to upgrade to do that?
    10k pool
    Mastertemp 400
    May 2014
    Laughlin, NV
    11,793
    Yes.
    Marty
    Jan 2018
    Chino hills, CA
    63
    Thank you for the help. I'll look into all of it and report back issues.
    10k pool
    Mastertemp 400
    Jan 2012
    'burbs of Augusta, Georgia
    8,852
    I'd try using PoolMath on the computer if you're having trouble seeing it on the mobile device.
    We avoid the use of dry acid as its not good for plaster nor salt water chlorine generators. MA is much better for dropping pH. Using straight MA on stains can be iffy as you might cause a change in the plaster too.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jan 2018
    Chino hills, CA
    63
    I figured out my user errors with the app last night.
    10k pool
    Mastertemp 400
