Thread: backwashing
    May 2009
    Ontario, Canada
    84
    backwashing
    One more question....
    Last week we finally got around to backwashing for the first time since we hooked everything up end of June.
    When we backwashed I would say about 5+ cups of the sand also came out. Is this normal? Everything seems to be working fine....I just wasn't expecting that for some reason.
    Also just wanted to say that my water has been crystal clear all summer so far!
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: backwashing
    If the sand filter is new it is probably normal.
    As long as the sand coming out is a very fine grit it is normal, if the sand coming out looks exactly the same as the stuff you put in then there is a problem. With new filter installations it is normal to get increasingly less amounts of very fine grit sand coming from the backwash
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    May 2009
    Ontario, Canada
    84
    Re: backwashing
    It seems to me to be the same sand as what we put into the filter. hmm....but it stopped coming out. Should I try backwashing again to see if it does it again or is there a problem we should fix first?
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    112
    Re: backwashing
    After you backwash, don't forget to rinse for a minute or so to settle the sand back down in the filter, or some sand may come out into the pool
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
