Thread: No Pool Lights. Any battery or solar powered light recommendations?
    Jan 2018
    Mobile, Al
    98
    Hello All,
    Does anyone have a light recommendation for a salt water pool (16x35ft) which has none? I desire something that could be submerged and attached to the side of the pool.
    I looked at some in Walmart (see below) and I think four of these may work. I would have to attach the base to the side via caulking but should be do-able. Maybe you have a better suggestion.
    Ralph
    GAME Color Changing Swimming Pool Wall Light, 2pk - Walmart.com
    BasicTek's Avatar
    Oct 2016
    Lake Mary, FL
    795
    Re: No Pool Lights. Any battery or solar powered light recommendations?
    I got one like this when trying to spend my extra leslie $$$ before expiration. It works for about half my 11K gallon pool, but it has issues, it tends to float to a side and then it doesn't work as well, it's not very bright so you have to wait until really dark to see and I think I had to power it on to charge it (probably would charge better outside my screen). Anyway I didn't pay much and it ended up in storage somewhere...
    -Tim-
    Pool: 86 gunite/plaster screened IG 12K 14' X 29', Hayward 120 sq ft cartridge filter, Pentair Intelliflo 2 VST, Hayward SwimPure 40K SWCG, Hayward Poolvergnuegen autovac,
    Heat: 280 sq ft Ultrasun solar Panels, Pentair Solartouch Ctrl, (solar cover and reel)
    Tests: Taylor K-2006C & K-1766 w/ speedstir
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,597
    Down lighting the pool may be most most effective, barring renovations.
