Thread: Might be time to replace
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    I don't think I'll be getting a new viewing glass. I have a good idea of how long the pump needs to run to backwash. It looks like I'm going to have to do some cutting further away and incorporate a new elbow.
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,860
    Re: Might be time to replace
    Mo,
    I agree... not really needed...
    Oct 2017
    Roscoe, IL
    221
    Seems like they should just use a section of clear PVC pipe if they want a visual rather than that contraption they have.
    I didn't even realize you could get clear PVC pipe until a year or two back. Not usually carried in stores but it's rated the same as white or other colors and is glued with regular PVC glue.
    Hot tub: Indoor Intex 28409E "Six Person" inflatable. 290 gallons. Taylor K-2006 test kit with Taylor 9265 Speedstir and TFT CYA test. Using dichlor/bleach/borax/muriatic acid.
