Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Salt cell questions, sand filter 3 ?s
    Lmlduradenali's Avatar
    Jan 2018
    Myrtle beach SC
    77
    Hey guys trying to ask all I can prior to open season and thanks for all the help
    Back ground I bought a house with a salt pool
    Figured out the computer functions and how to time every thing etc
    The salt cell is about 3 years old, Iím sure it not producing the levels needed.
    Am I better off going clorene instead? Can put a out of line chlorinator for like 100 bucks
    Input?
    12k Gallon in ground-hayward prologic controller -Hayward S244T sand filter
    Hayward super pump 1.5
    SWG Hayward T-Cell 9
    K2006C Test kit
    dolphin nautilus plus cleaner
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,541
    Re: Salt cell questions, sand filter 3 ?s
    Nice to meet you via TFP
    A salt cell will generally last considerably more than three years. A common reason for shorter life is free-floating algae (which is not visible to the naked eye). TFPC uses a process to annihilate the algae, and then chlorine consumption drops much lower. Also common, but somewhat less, is scaling in the chlorinator cell leading to frequent cleaning which degrades the cell. This can be avoided with good water chemistry. A salt water pool is also a chlorine pool; it's just a more convenient way to make chlorine.
    Using solid forms of chlorine usually leads to a buildup of stabilizer which can cause longer term problems. If you get a lot of rain and splashout, the problems take longer to develop. If you remove the salt water chlorinator, then your best option is chlorinating liquid which is a trouble-free option.
    There's a fair chance that your SWG is not keeping up because of algae in the water. If you want to rule out algae, you'll need a test kit with the FAS-DPD chlorine test, and you can then do an Overnight Chlorine Loss Test Overnight Chlorine Loss Test which will show whether or not algae is present. The most recommended test kit is this one:
    TF-100 Test Kit ‚ĄĘ
    The bonuses of doing your own reliable testing is that your costs will go down a whole lot more than the cost of the kit, your water will be nicer to swim in, and your water will look amazing.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,858
    Quote Originally Posted by Lmlduradenali View Post
    The salt cell is about 3 years old, I’m sure it not producing the levels needed.
    Input?
    L,
    I'd be interested in what specific cell you have and how you determined "how to time everything"???
    How long are you running the pump?
    What % of output is the cell set for???
    What are your current chemical readings... Especially FC and CYA levels???
    FC
    CC
    pH
    TA
    CH
    CYA
    And how cold is the water, since most cells do not generate any chlorine when the water temperature gets below 50 degrees..
    Jan 2018
    Myrtle beach SC
    77
    I am below 50 degrees for sure...
    Here is a picture hope it helps
    K2006C Test kit
    Jan 2018
    Myrtle beach SC
    77
    K2006C Test kit
    Jul 2014
    Bedford, TX
    9,858
    L,
    A T-9 cell will produce an increase in your FC of about .30, per day, in your size pool, when running at 100% output.
    Most pools use 2 to 4 ppm of FC per day.. less in the winter and more in the summer... so let's use 3 ppm per day.
    This means you need to run your pump for at least 10 hours a day and have the output of the cell set to 100%... or run your pump 20 hours a day with the pump set to 50%, to generate the chlorine your pool will use everyday...
    This of course assumes that the pool has the required amount of salt in it to allow the cell to work.
    Here is a pretty good troubleshooting guide... Diagnosing and Troubleshooting Your Hayward Aqua Rite System
    The one good thing about the Hayward cells is that most all Leslie's pool stores have the ability to test them...
    Thanks for posting,
    Well, apparently my "calculator" is not working today, as I really screwed up the FC numbers... It has to the calculator, how could it possibly be me... ???
    I've corrected them... I think..
    Jan 2018
    Myrtle beach SC
    77
    So 2 more questions
    My Hayward prologic shows clorinator off.... can I manually turn on? Water temp still a little low
    K2006C Test kit
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    You can try to turn it on. Most SWCG's shut off at around 50F. Some even closer to 60F.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Input?
    BTW- your pool is already a chlorine pool, it just gets its chlorine made by the SWG cell instead of you adding it.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2018
    Myrtle beach SC
    77
    ?thanks Iím still learning! Thank u so much pal
    K2006C Test kit
    domct203's Avatar
    Jun 2015
    CT
    3,959
    No worries. While itís hard to remember, there was a time in my life 5 years ago when I didnít own a pool, and 4 years since I found TFP. Iíve learned so much since, and you will too.
    Theyíll be a day when youíll be the one helping.
    Dom - TFP Guide
    Dec 2017
    Clinton TN
    13
    First off, the cell is shut off due to cold, if the pool is running you will need to add chlorine until the swg starts working.
    Second the Cell might need cleaning. Shut off the pool and remove the Cell from the unions and look to see if it has calcium looking build up on the plates. If it needs to be cleaned I use a Hayward union (GLX-CELL- UNION with a pc plug in it. Put the union on with the Cell unplugged from the box and put it in a bucket and fill the Cell with muriatic acid and wait for it to stop fizzing. Rince and reinstall, let water ru n through before plugging back in.
    To test a salt cell go to diagnostic on the menu, click once to the right and after all is said and done if it is above 3 amps the Cell is good.
    Dec 2017
    Clinton TN
    13
    Quote Originally Posted by Siber Express View Post
    BTW salt level needs to be between 2700 ppm and 3400 ppm and above 4000 ppm will cause high amps
    Jan 2018
    Myrtle beach SC
    77
    Problems after problems
    Now today and last night I noticed pool had lots of stuff in it.
    Back washed today and have some sand in sight glass. Guess this is a sign of a finger off the tree inside if messed up
    Let me add
    New multi port valve with spider gasket...
    K2006C Test kit
    What kind of stuff?
    Support the site
    Jan 2018
    Myrtle beach SC
    77
    Sorry
    Sand
    So I would have to assume the lateral center pipe assembly is what I should order with all new send
    K2006C Test kit
    Dec 2017
    Clinton TN
    13
    Let me add
    A little sand in the sight glass is nothing to worry about. Sand coming out of the return lines is.
    Jan 2018
    Myrtle beach SC
    77
    Ok, so not ness a issue well I feel a little better
    K2006C Test kit
    Is filter sand coming out of the returns and piling up on the floor?
    Support the site
  20. Back To Top    #20
    Jan 2018
    Myrtle beach SC
    77
    One is off
    One is on
    And inside
    K2006C Test kit
