Thread: Free Chlorine in the Deep End
    Oly's Avatar
    Jun 2017
    Fresno, CA
    450
    Why is it that when I test FC in my pool water I get different numbers depending on where I take the sample?
    When testing from my filter return pipe located in the shallow end I get 5.5ppm FC and when testing 18" from the surface at the deep end I get 6.5ppm FC.
    I am using a suction side pool sweep which is pulling 80% (estimate only) from the bottom of the pool and remainder from the skimmer box where my pool sweep hose is connected. I am using a Pentair adjustment valve to keep the sweep from climbing to the surface and breaking suction.
    So why the difference? Any deep ideas?
    27,000 gallons of central CA well water housed in a fiberglass coated concrete/plaster pool, dug into the most productive top soil on earth and surrounded by an urban forest.
    Cleaned with a Pentair 48 sq ft DE filter and a Dolphin Discovery (S200) robot. 250 gal Hot Springs Solana RX stand alone spa. Taylor K-2006. My first thread... New Old House, New Old Pool....
    Jan 2012
    'burbs of Augusta, Georgia
    8,865
    Re: Free Chlorine in the Deep End
    I'd say it was circulation variables and possibly sun burn off more in the shallow end but the deeper water is shading some of that water from the UV rays?? Just like the water in the shallow end is warmer than the deeper end.
    I dunno... that's my theory
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    JoyfulNoise's Avatar
    May 2015
    14,231
    In a completely mixed volume of water, the chemical levels should be all the same. Pools are not very efficiently designed for mixing so there can be some stagnant areas. There is also the theory, as YS stated above, that CYA adds an anamolous screening effect to UV light - ie, not only does the fact that chlorine binds to CYA and gets protection from UV that way but also the cyanurate s themselves absorb some of the UV and down-convert it to less harmful radiation. This effect has yet to be proven as its difficult to measure UV absorbance differences at different pool depths. But it would explain why higher levels of CYA seem to reduce chlorine loss more so than just the chemical binding theory would predict.
    Simplest answer - stagnant water + testing error yields a 1ppm difference.
    Matt
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Quote Originally Posted by Oly View Post
    You are pretty much getting 6.0ppm +/- 0.5ppm, using a 10ml sample thatís +/- 1 drop. No worries there.
    Between not-so perfect pool water mixing and standard testing tolerance, I would expect this.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Oly's Avatar
    Jun 2017
    Fresno, CA
    450
    Yes a 10ml sample but initial color a deeper barbie pink and a two drop reagent difference to get back to clear. Pretty clear to me that the difference cannot be explained by testing error alone.
    Now the mixing issue is where I believe the difference may be and it appears to be the bottom of the pool (less FC) verses the 18" deep (more FC) but I would need to actually test the deep water at depth not simply the return line.
    So regarding layering of chemical additives in poorly mixed cold pool water, would you expect FC or CYA concentrations to be different at depth. In other words would these soluble materials naturally tend to accumulate at different depths if the pool water was not well mixed?
    May 2015
    14,231
    No, there is no gravity settling in the chemistry, that’s totally wrong. The variation comes from inefficient mixing of the pool.
    Matt
