Hi everyone! I really wish I would have found this forum before I started up my pool. I can already tell I have done some things wrong based on what I found here in the Pool School --> New Startup thread.
The background is I just built my pool (filled on 2/9) and GC’d it myself rather than going through a pool builder. All the subs were great for the most part, and even though the finish is looking great thus far with most all of the dust gone (black exposed aggregate), the finish guy isn’t giving me much support in the start up, so I have a lot of questions. He basically dumped in a bunch of muriatic acid and said he’ll come back in a few weeks, which doesn’t sound right to me.
What I have done so far:
- First things first, not really a question, but I just ordered the Taylor K-2006c, and as a homebrewer, I am not a stranger to water chemistry, so looking forward to sponging up all this new knowledge!
- I’m in Orlando so it’s already getting hot out. The “pool store” guy has recommended that I dump 4 lbs of Suncoast dichlor shock (did 2 lbs on Saturday and 2 more yesterday) as well as drop 2 chlorine tabs in my skimmer just to get something in there to protect from algae growth before I can start adding the salt on the 28 day mark. Based on this forum's Startup thread, it seems I was given bad information.
I have fairly iron heavy well water, and added 2 bottles of Jack’s Magic - Magenta on the fill, and the water looks pretty clear albeit still a little tinge of yellow but getting better.
- Pump was running for 72 hours straight at 2500 speed after the fill per recommendation from my finish guy, yesterday was the first time I turned it off (it was off from 11pm - 7am) and now I have it running 10 hours a day from 7am - 5 pm until I get the chemistry right.
Questions:
1. Is what I am doing with the pump ok? How long of a duration should I be running it during the first 30 days?
2. pH is still hovering around 6.8 from the acid startup.
a: Since the dust is pretty much gone (still a bit in the floor of the spa) I should start adding soda ash to bring up the pH, or keep it like it is until every bit of dust is gone? It's only been 4 days since the finish was plastered. I wasn't sure if the need to be acidic was solely to dissolve the dust, or part of a longer curing process.
b: Should I be trying to balance all aspects of the chemistry this early on, or just pH and chlorine? Guy at pool store said the aggregrate shedding will wreak havoc on the chemistry for a few weeks anyways, so it will be tough to get a true view of what is going on.
I know it was long, thanks for reading.
Questions:
