Thread: Intellichlor May Be Kaput
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    My IC40 is about 4 years old. Says it has about 40% life left but the cell light now blinks green all the time while all other lights are working fine. How do I determine that this cell is indeed dead and I need a new one? Just go by the blinking light?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,909
    Re: Intellichlor May Be Kaput
    Mo,
    A flashing cell light on an IC40 means the cell needs to be inspected and most likely cleaned.. Not sure if you have done this already or not.
    There should be no calcium build up on the internal plates. If there is, you need to soak the plates in diluted Muriatic acid.. 1 part water and 1 part MA.
    They sell a cap that goes over the end of the cell that allows you to fill the cell with the MA solution.
    It is best to use a garden hose and to remove as much scale as possible before using the MA.
    I only soak long enough for the bubbling to stop and then I rinse the cell out...
    In more than three years I have never had a blinking cell light and have only cleaned my cell once.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Quote Originally Posted by Jimrahbe View Post
    Mo,
    Thanks Jim. I should have mentioned that my cell is clean. I gave it a soak this past weekend. I'll admit I was not good about calcium buildup this past year or so, which lead to longer MA soaks which I know is not good for the cell.
    Jul 2014
    Bedford, TX
    9,909
    Mo,
    In theory, the cell produces no chlorine when the cell light is blinking.. You can test that theory, by taking a water sample with the cell off and then again with the cell on and compare the difference. If the cell is working the FC will be much higher.. Of course you would take the sample right at the pool return.
    I 'assume' your cell light is constantly flashing.. and not going on for five minutes and then off for five minutes, which would be normal...
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    338
    Mo,
    Correct, it's not the flashing that is done at startup. I was bad with my pool the past month or so, so there was no chlorine when I was correcting things this weekend. I slammed it and cleaned the cell, but the fact that there was no chlorine could be the indicator that it isn't producing.
