Results 1 to 20 of 20
Thread: Rolled Bond Beam Removal
    Dec 2017
    Gilbert
    11
    What tools are you guys using to remove rolled bond beams to make way for coping?
    I would imagine it is a large grinder with a concrete wheel, but would like some input. If so, what size wheel?
    Thanks in advance!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,915
    Re: Rolled Bond Beam Removal
    cc,
    Please keep in mind that most of our members are pool owners and not pool builders so it might take a day or two to get an answer this time of year.
    I'm pretty sure they just slapped the coping right on top my bond beam.. So what makes your bond beam different???
    Thanks for posting,
    Jan 2018
    150
    Quote Originally Posted by ChevChelios View Post
    Thanks in advance!
    I'm clueless about pools, but have done plenty of construction work that included cutting concrete/masonry. I would guess that you'd want to use a large concrete saw, 12" blade or larger. Trying to use an angle grinder with a blade large enough to cut all the way through the bond beam sounds difficult and dangerous.
    Quote Originally Posted by Jimrahbe View Post
    cc,
    Thanks for posting,
    A rolled bond beam is taller than a standard bond beam, and the top of it is formed such that it also serves as the coping. Can be formed into the shape of standard coping, or more commonly is completely rounded over like this:
    https://www.precisionaquatics.net/co...s/IMG_0968.jpg
    Currently renovating 1970's era IG 34'x18' rectangular sports pool with 6'x10' baja shelf
    22,000 gal, Triton II TR-60 sand filter, antique Sta-rite pump
    Jul 2014
    Bedford, TX
    9,915
    Quote Originally Posted by MinerJason View Post
    Jason,
    Thanks for the rolled beam info.. I have never heard of this before and after seeing your pic, I can see why....
    Is this a renovation, or what?
    Support the site
    Jan 2018
    150
    Jason,
    Hah! Yeah, I can only imagine how difficult it is to keep mineral deposits off the waterline. I'd wager the OP could tell us though...
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    4,084
    A ring saw would be the ticket.... but you could probably get it done with some patience and a demo hammer.
    You really can't beat what those saws are capable of doing.
    -Brian-
    Pool/Spa, Pentair Equipment
    JoyfulNoise's Avatar
    May 2015
    14,233
    Ok, seeing that video makes me want to go and cut down an interstate overpass, or a bridge or something....
    Matt
    Dec 2017
    Gilbert
    11
    While a gas concrete saw would be ideal, I can’t fathom a worker holding it not only horizontal but also above their head for an extended period of time.
    I had had a rolled beam removed from my pool, but unfortunately was not around when they did so.
    Thinking it has be a large angle grinder.
    Anyone ever seen how theirs was removed?
    Quote Originally Posted by JamesW View Post
    Yes. Removing rolled beam and cutting in for waterline time as well.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    4,084
    If it was me I'd set up some scaffold so the saw ended up mid chest and go to town. They really aren't difficult to handle...
    An angle grinder capable of a 12" cut would need a blade bigger than a car tire...that's how someone's head gets lopped off.
    It would probably be just as easy to snap a chalk line and chip away
    -Brian-
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    4,084
    A few jobs we've done required precast hydro conduit tubes and vaults installed that were 7500 PSI and 8-12" thick. We had 2 concrete chainsaws and 4 ring saws running non-stop to make the necessary cuts. When you left for the day you'd be covered head to toe in a muddy slurry and could only hear ringing in your ears...
    We really grew to appreciate the ring saws though. Prior to their use we'd have to make step cuts in the concrete because a 14" blade was only good for a 5" deep cut.
    -Brian-
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,606
    Saw tracks bolted to pool wall, & outsourced to concrete cutting companies & don’t cut the “7 irons”
    Jul 2014
    Connecticut
    2,606
    Wanna borrow my diamond chain saw? You can plunge cut a bridge...
    May 2015
    14,233
    Quote Originally Posted by PoolguyinCT View Post
    I’m afraid that once I spun that puppy up there would be no stopping me until I ran out of gas....the neighborhood would like a war zone!
    I now know what to get for the zombie-apocalypse! Hook that baby up to a Boring Company flamethrower (modified, of course, to shoot a flame at least 6ft) and I’ll be taking down zombies left & right...
    Matt
    Jul 2014
    Connecticut
    2,606
    OP - just curious, is this your pool or are you doing contract work?
    Dec 2017
    Gilbert
    11
    My pool.
    Jun 2016
    Southern California 562
    96
    Chip that out like regular pool plaster.
    Dec 2017
    Gilbert
    11
    Quote Originally Posted by Erdons View Post
    Yeah that wouldn’t end well. The rolled beam is concrete. Not the plaster and pebble you are thinking.
    Jan 2018
    Central Coast NSW, Australia
    38
    I can't see that well from the photo. Does the rolled concrete bond beam actually project out over the pool with a lip ?
    If not, then it looks a lot like our pool which we just had resurfaced. The pebble crete surface was simply jack hammered off carefully over the whole pool surface, they just took off the top layer. Then the we had a concrete slab laid around the whole pool area with travertine pavers and coping around the pool, waterline tiles applied, before the new surface was applied in the pool.
    35,000 Litre Concrete Pool, NZ White Pebble with blue and green glass beads.
    NSW Central Coast of Australia, Temperate climate.
    SWCG, Cartridge filter with hydrocyclone prefilter, Solar heater.
    Pool Cleaner: The Pool Cleaner
  20. Back To Top    #20
    Jun 2016
    96
    To elaborate on this, he will have chalk a straight line along the inside and then take a concrete saw and cut along that line. Then for most controlled demo use a chipper to knock it out, it will not be an easy or fast process that’s for sure. Trying to grind an inch of concrete is hard I can imagine trying to do 100+ feet at 4-7 inches.. would be a fool...
