Results 1 to 9 of 9
Thread: Above ground pool - green pool clean up
    Feb 2018
    Australia
    3
    Hi there,
    I'm new here! I really need your help.
    I moved to a house with an above ground pool. Approx dimensions, 5 mt long, 3 mt wide and 1.15 mt height, oval shape.
    I have no experience with pools at all.
    It's a salt water pool, the pool looks greenish, hasn't been cleaned for a few months. I took a sample and the water looks clean, I guess its mostly the old alguea stucked there.
    I have a few questions,
    * Do chlorine and salt water pools use the same chemicals?
    * How can I clean it so its not green anymore?
    * I've found information online about cleaning the chlorine pool but not the salt one. Can I follow the same process?
    * What are the safety procedures or protective equipment to use when handling these chemicals?
    Thanks so much for your advice!
    Sherry
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Above ground pool - green pool clean up
    Welcome to the forum!
    First thing you will need is a proper test kit. ClearChoice Labs markets a proper test kit in Australia. Order one as soon as you can.
    In the interim you can add 1 liter of 8.25% bleach (if you have to buy a different strength use PoolMath to adjust) each day until you get your kit.
    Answers to your questions:
    Yes
    SLAM
    Follow TFPC. See Pool School above.
    Mainly be aware of not getting the bleach on your clothes. When you need to use acid be aware to not get it on you or breath its fumes.
    Can you add what city in Australia? Pretty big place and climate makes a difference. Also please fill out a signature - see Pool School - Getting Started
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Quote Originally Posted by Sherry12 View Post
    Hi there,
    Sherry
    Hello Sherry, and welcome to the forum!
    If your pool uses a SWG (Salt Water chlorine Generator), then it is really a chlorine pool, it just uses salt to automatically make chlorine instead of you manually adding chlorine.
    Don't worry about not knowing about your pool. We all started that way, and with TFP's help, you'll be a pro in no time.
    Your #1 priority should be getting a proper test kit. Nobody will care for your pool as good as you will.
    It's nice to have you with us.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,723
    Welcome to TFP Sherry
    Follow the advise above and also start to brush the pool as often as your arms will allow. It keeps the green stirred up so it can be filtered out and doesn't let it sit and grow.
    From your dimensions you have approximately 15,000 liter / 3,800gal pool.
    When you get a chance you should add you pool equipment info to your signature as outlined here: Pool School - Getting Started
    32K IG Vinyl, Lazy L, Hayward SuperPump 1.5hp, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added. <32
    Feb 2018
    Australia
    3
    Hi Marty,
    I live in Melbourne Australia. The issue is that i live in the edge of the city. So not many shopping options.
    In the bunnings shop i got a free test, took my own water. But it didn't ask me (free computarised ptogram you just fill out) if it was for chlorine or salt.
    That's why i dont know if i should follow thst advice. Ive attached the test results.
    Screenshot_2018-02-16-01-48-14.jpgresults Screenshot_2018-02-16-01-48-14.jpg
    Feb 2018
    Australia
    3
    Hi Marty,
    How can i asd tge photo?
    May 2017
    Coventry, CT
    335
    The recommendation on that print out is a mixed message at best. I would recommend just not using that system or store testing ever again, they just add confusion to a very simple problem.
    Follow Marty's advise. Get a good test kit and in the mean time add 1 liter of 8.25% bleach (if you have to buy a different strength use PoolMath to adjust) each day until you get your kit.
    20' X 40' IG vinyl lined; 31,300 gallons; built ~30years ago
    Hayward 1HP Single Speed Pump w/Sand Filter
    Taylor K-2006,Rola-chem sodium hypo feeder/ 15 gallon tank
    Fill from soft/neutral well water, low flowrate well pump
    May 2014
    Laughlin, NV
    11,793
    Free pool store tests are as good as what you pay for them.
    Please see my post #2. You need your own test kit to manage your pool.
    Take care.
    Marty
    domct203's Avatar
    Jun 2015
    CT
    3,959
    I'll bet that the FC is really zero, but I would not trust anything else.
    Without reliable testing it is hard to give good advise..... If that CYA level (stabilizer) is at all close to accurate, you are going to need to exchange a good portion of the water in that pool. If that is the case, there is no sense trying to balance until your CYA is at a proper level.
    To try and keep it from getting any worse add the liter of bleach as recommended until you get the proper test kit.
    Dom - TFP Guide
