Thread: How high is too high for standing water to get on an IntelliFlo ?
    May 2017
    Lexington, SC
    144
    My equipment pad has recently become somewhat of a low point after some grading we did to the area around the pool. I haven't had a downpour yet to see how it goes, but I'm worried that there could be standing water on the pad such that the water level rises up onto the pump a bit. How much water can the IntelliFlo handle around it before it gets worrisome. I know I wouldn't want it up near the LED screen, but how about the lower portion of the pump?
    Thanks in advance!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,883
    Re: How high is too high for standing water to get on an IntelliFlo ?
    raw,
    There is a drain hole in the bottom the pump, just before the motor...
    I personally would not want my pump to see any water except what might happen in the rain..
    I suggest that you re-grade or raise your equipment pad.. Maybe just enough to have a place for the water to run off...
    Thanks for posting,
    May 2017
    Lexington, SC
    144
    Quote Originally Posted by Jimrahbe View Post
    raw,
    Thanks for posting,
    Thanks Jim. It makes me a little nervous too. I think re-grading might be the best option so I won't have to start cutting PVC etc to raise it.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    I'm going to echo Jim, those motors are only designed to resist rain and water splashing. You should never expose your pump to directed water (pointing a garden hose at it) and you should never submerge it to any level.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2017
    Lexington, SC
    144
    Thanks. I'm going to do whatever I need to do to keep water away from it. Too big of an investment not to!
