Results 1 to 12 of 12
Thread: Wrong Grout Color
    Jul 2017
    Frisco,Tx
    5
    Wrong Grout Color
    Hi there everyone I am new to the forum! I am currently building a pool in the North Dallas area. This not how I wanted my first post to be. Well here goes.
    We we had our water line tile installed yesterday which was a pretty cold day here. The tile guys assured us it was ok. So let’s now talk about the problem. The grout is the wrong color!! It is suppose to be a tan color. I am not sure what my options are. Anyone have any ideas?
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Wrong Grout Color
    Welcome to the forum!
    Speak with your pool builder. Did you have the grout color documented? Only way to change it is to remove the tile and start over.
    Take care
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    What color was installed?
    Support the site
    Jul 2017
    Frisco,Tx
    5
    Yes we have it all documented. I was afraid of that. Also should the grout be a sanded grout or unsanded? We are not using glass tiles.
    Biscuit is the color installed. It should have been a tan/ cafe color.
    If you can't live with it, you're going to have to get the contractor to redo it.
    Support the site
    Jul 2017
    Frisco,Tx
    5
    We have a different tile going on our fire and water feature wall that has tan edging. I don’t think the white( biscuit) will match very well.
    If the contractor made an error that you're not going to be happy with, then it's on them to make it right.
    What color is the tile?
    Do you have a picture?
    Support the site
    Jul 2017
    Frisco,Tx
    5
    I will try and post pics in the morning. I am not able to get them to post from my phone right now. It is QDI Lagoon Venezia on the waterline and the back columns are from Noble tile NWSP 138 Maluku.
    If the tile is 6x6 with straight grout, the builder might be able to cut out the grout and redo it.
    Ultimately, it comes down to how important it is to you. If it's got to be how you want it, then it can be done.
    Let's see what the builder says.
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,054
    Pics please..............if it is documented then they should make it right........it is up to you what you will accept as "right"....remove and redo or $$ back for their mess up.
    Kim
    BeachSunH20's Avatar
    Feb 2017
    Las Vegas NV
    143
    Wrong Grout Color
    When we had our pool built we choose a tile that didnít look the same when they installed it as the sample did. We didnít like it and our builder understood . They removed it and installed a new tile we actually liked more. They did not give us any problems.
    Built 9/2016 -10k pool, IG Concrete pool/spa - travertine coping/deck - All Pentair Equipment - Pentair Clean & Clear Plus Cartridge filter-Master Heater 400,000- Pump Intelliflo vst - color plaster - rebel cleaner- Auto -tablet-Chlorinator -Screen logic connect- variable pump - Test Kit Taylor 100.
    Jan 2018
    150
    Quote Originally Posted by Derrick8147 View Post
    Depends on how wide the grout joints are, with joints <1/8" requiring unsanded, and wider joints requiring sanded. Waterline tile is generally installed with narrow joints to minimize the rough surface for mineral deposits to cling to.
    Currently renovating 1970's era IG 34'x18' rectangular sports pool with 6'x10' baja shelf
    22,000 gal, Triton II TR-60 sand filter, antique Sta-rite pump
