Results 1 to 8 of 8
Thread: ph Balance Question
    Jul 2017
    Fulshear, TX
    9
    ph Balance Question
    I am a new pool owner and have been using the TFP test kit to monitor and manage my water.
    I have an inground, pebblesheen (plaster) pool with a volume of approximately 27,500 gallons.
    I test my pool weekly and it reflects a ph of 7.8. I am using the pool math app which recommends that I add muratic acid (10%) every week - which I do. However, the ph doesn't seem to come down week to week. It has been raining recently, and wondered if this leads to the ph creeping up.
    My current readings are:
    FC: 3
    ph: 7.8
    TA: 80
    CH: 250
    CYA: 20
    Temp: 57 deg F
    I added approx. 24 oz of acid today after taking the above readings.
    What is the best method to slightly lower the ph? Does rain raise the ph? I am missing something?
    Thanks!
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: ph Balance Question
    Welcome to the forum!
    A pH of 7.8 is fine. I would suggest not adding it until you see 8.0. Then only drop to 7.6 and see if the rise slows. Every pool water is a bit different.
    Rain does raise your pH due to aeration - just like a bubbler, waterfall, sheer descent, spillover, etc. Do you have any of those?
    Can you fill out a signature? See - Pool School - Getting Started
    I would suggest you need to raise your CYA over the next month. How high depends on your method of chlorination. Be sure to use the FC/CYA Chart
    Good luck - and welcome again!
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jun 2014
    17,808
    Welcome to the TFP forum!
    Jul 2017
    Fulshear, TX
    9
    Thanks! Signature updated!
    I have a spillway from the spa that runs approx. 8hrs per day; sheer descents only come on when manually turned on. I am currently using a combination of liquid bleach with chlorine tabs. The pool is relatively new, so I assumed my CYA would naturally go up as I use more tabs and get more use out of the pool when it warms up.
    So, will I just normally need to periodically add acid to keep the ph in check due to the water features?
    Thanks again!
    Volume: 27,500 gallons, In ground, Pebble
    Pentair FNS 60 DE filter w/Pentair Inteliflo VSF Variable Speed Pump
    w/Spa, spillway, & sheer descents; using Chlorine, w/ Pentair UV Light & Polaris280
    Install complete November 2017 using TF-100 Test Kit
    May 2014
    Laughlin, NV
    11,793
    Do you have automation and actuated valves? If so, it would be best to set it up so the spillover only runs 30 minutes or so each day. If not, then eventually you will probably want to add it!
    Yes - your pH will go up due to the aeration. You will need to watch your TA as if you are too aggressive on the pH side, you can drop your TA too low.
    If you are going to use the tabs to add CYA that is OK. Use PoolMath, Effects of Adding Chemicals, to know when you are about to hit 40 ppm. If you plan to DAILY add liquid chlorine starting in about 6 weeks or so, that is the CYA level you should target.
    You may eventually want to look at a SWCG or Stenner pump system for your daily FC maintenance.
    Take care.
    Marty
    Jul 2017
    Fulshear, TX
    9
    Yes, I have the Pentair Easytouch, and revise the program accordingly.
    i might look into the metering pump set up. I can't use a SWG as I have a lot of natural flagstone. They source most of the stone from Oklahoma where I am located and it is not very resilient to salt water.
    Thanks!
    May 2014
    Laughlin, NV
    11,793
    From all reports that is false. Have you seen natural flagstone around a SWCG pool that has had the pH properly managed and is it damaged?
    The natural stones are harmed by high pH. Not the salt.
    Take care.
    Marty
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,705
    Every pool has salt in it, it's closer to swg levels than anything else
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
