Thread: Pool Equipment Housing/Enclosure or Covering
    Dec 2016
    Raleigh, NC
    107
    Hi all!
    We put our pool in last season, but never built an enclosure around it. Thankfully it is almost always in the shade, so we didn't have any sun beating down on it...but we want it covered and protected this Spring to keep it in good shape. Here is a picture of what we have: 20180207_173912.jpg
    If you have a similar set up, could you share pictures of what you have done? Something purchased or built. Hubby is a handy engineer, so he can certainly build something! Thanks!!!
    IG Fiberglass 16x37, 3ft6in-6ft Deep, 13,300 Gallons (540 sq ft), Pentair Sand Dollar Filter, Pentair Superflo Variable Speed Pump
    Jun 2014
    17,826
    Re: Pool Equipment Housing/Enclosure or Covering
    The ideas out there are limitless, and you can see others by doing a search. But we have a similar pad set-up, and here's what I did:
    Nov 2011
    Magnolia Texas
    80
    I've though about building a little cover over the pool and cleaner pumps as they are in the sun most of the day. I wonder how many people have done this?
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,873
    ny,
    Here is a pic of the shed I built over the pool equipment. It covers the pool equipment (first door) and the some storage for yard equipment and pool stuff (second door). I had the advantage of having the extra decking poured for it when the pool was built..
    Thanks for posting,
