Results 1 to 8 of 8
Thread: Pool Pump Replumb
    Apr 2014
    Huntsville Al
    15
    Pool Pump Replumb
    I'm thinking of rerouting the connection between my pool pump and filter as shown. Does anyone see a problem with this? I plan on adding the drain spigot into the new line also.
    22k gal, 18 x 36 IG vinyl, Pentair 320 cartridge filter, 3/4 HP 2 spd WhisperFlo pump, Intermatic P1353 timer, Dolphin Nautilus Plus, Circupool Universal 40 SWG
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,705
    Re: Pool Pump Replumb
    If it's not broke don't fix it
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    I'm not the hydraulics guy (though there's someone here that is, maybe he'll check in), but I know I've read somewhere that a good chunk of long straight pipe coming out of the pump like that is a good thing. It might even be in the manual for some pumps, as in "required." More importantly, a tight curve so close to the pump's exit can mess with its flow (somehow). Now sure why, off hand, but I'm fairly certain that's why the original plumber did it that way. The length of pipe before the pump is also important. Read up on that a bit before you chop-chop...
    Your system looks a lot like mine used to. That's a tab feeder, right? Do you use a lot of tabs? Exclusively? Do you know how tabs can affect your pool's chemistry? If not, may I interject some advice about that? Using a lot of tabs can send your pool's water into a spin. TFP's Pool School can get you on a better path. Worth a read. (Link above.) I know that wasn't your question, but I wish someone had warned me about tabs before they caused me more than a little grief...
    12300 gallon IG pebble, freeform 19x28, 1 skimmer, 3 returns, no floor drains, auto fill. Pentair: EasyTouch PSL4, ScreenLogic2, Indoor Control Panel, Intelliflo 2 VST, IntelliChlor IC40, IntellipH, CCP320 Cartridge Filter, MasterTemp 250 Heater, Rebel Suction-Side Cleaner, IntelliBrite. Solar and cleaner actuators. Heliocol HC-50 8-panel solar heating. FlowVis Flow Meter. Taylor: K-2006 and K-1766 Test Kits, SpeedStir. City/softened water.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,854
    I,
    Why??? There would be no obvious advantage to do it??? In fact, what you have now may even prevent the filter from draining back through your pump when you take the lid off..
    Are you having a problem that you think is related to that part of the plumbing???
    Thanks for posting,
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Quote Originally Posted by Jimrahbe View Post
    I,
    Thanks for posting,
    Interesting. My system has a check valve on that section of pipe. Maybe that’s why it’s there.
    Apr 2014
    Huntsville Al
    15
    Thanks for all responses. No, I don't use the tab feeder except for when on vacation. I manually dose with chlorine regularly. I was going to add a larger valve on the line to the filter to make draining the pool easier. Sometimes we get a lot of rain, and I have to run the pump for several hours to drain the pool by a few inches through the small spigot. I am going to leave the plumbing as is for now - and maybe put a larger drain valve on the tee.
    Jul 2014
    Bedford, TX
    9,854
    I,
    Sounds like a good plan to me...
    But, the next time you have to re-plumb the pump, I suggest that you ditch the threaded connections and use pump unions....
    They eliminate the eventual leaks at the threaded ends and look like this... Custom Molded 21063-200-000-2PK Union Threaded 2 inch MPT x 2 inch Slip for IntelliFlo, 2 Pack
    You can buy them at a lot of places, the link just has a couple of good pics.. The key is that they have an O-ring on the threaded end that eliminates any leaks..
    Apr 2014
    Huntsville Al
    15
    Thanks for the suggestion on the pump unions.
