Thread: Pentair Intelliflo Making increasing amount of noise
    Nov 2017
    Conroe, Texas
    14
    My Intelliflo started getting noisy last fall, and has become so loud the next-door neighbor is complaining. I had a pool service come out to take a look and they said they would not attempt to fix it....they would only replace it. It's four years old. Seems very expensive to replace. Anyone know if I might be able to get it repaired for a fraction of the cost? Thanks
    25,500 gal, 819 sq ft, IG pebble tech; Easy Touch 8, Intelli-Flo 4x160 VS, Pentair 400,000 BTU nat gas heater, Jandy Valves, Pentair IC40 SWCG, Polaris 9550 robot cleaner
    sktn77a's Avatar
    Chapel Hill, NC
    738
    Re: Pentair Intelliflo Making increasing amount of noise
    Well, it depends on your definition of "a fraction"! Presumably it's the motor that's making the noise and not the impeller assembly ("wet end"). The wet end and controller contibute significantly to the cost of this pump but the motor isn't cheap, either. Nevertheless, you should be able to get the motor replaced by a pool repair guy for about $500-$600 (about 1/2 what they'd charge you to replace the entire pump).
    Keith
    15,000 gallon in-ground gunite/plaster pool, 1.5" PVC plumbing
    1.0HP Sta-Rite DuraGlass P2R pump, Hayward S244T sand filter
    Teledyne-Laars Lite-2 250k heater, Hayward CL200 chlorinator
    Polaris 380/Hayward 6060 booster pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,910
    t,
    If it is a bad bearing kind of sound you can try just replacing the bearings.. If you are not a DIY kind of guy, I'd check around for a local motor shop and see if they can do it. I'm pretty sure you would have to take the motor to them...
    Nov 2017
    Conroe, Texas
    14
    Quote Originally Posted by Jimrahbe View Post
    t,
    Thanks for your ideas and replies y'all
